Home » Eclipse Projects » Riena » Eclipse package for Riena
| Re: Eclipse package for Riena [message #1013102 is a reply to message #1011623] |
Fri, 22 February 2013 14:44   |
Max Reeb Messages: 5 Registered: February 2013 |
Junior Member |
thanks for the quick help!
1. I have now installed Eclipse 4.3.
2. Created a target platform (see also attached screenshot..)
-Equinox Target Components
-Eclipse RCP
-Eclipse RCP SDK
-Eclipse RCP Plug-in Developer Resources
-Riena Core Target Components
-Riena Samples Target Components
-Riena Target Components
3. Importet the Riena Client Example
4. Added SWT to the build path
5. Added automatically the required plugins within the run configuration.
Now I get the following error by starting the example: java.lang.NullpointerException
I have no idea, if there are missing additional components are I have used a wrong combination of versions..
Thanks in advance!
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -application org.eclipse.riena.example.client.exampleapp
Command-line arguments: -application org.eclipse.riena.example.client.exampleapp -data C:\Users\******\Desktop\Software\EclipseWorkspace\kepler/../runtime-New_configuration -dev file:C:/Users/*******/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/dev.properties -debug C:\Users\******\Desktop\Software\EclipseWorkspace\kepler\.metadata\.plugins\org.eclipse.pde.core\SWT ExampleApplication/.options -os win32 -ws win32 -arch x86 -clean -console -consolelog
!ENTRY org.eclipse.osgi 4 0 2013-02-22 20:37:47.139
!MESSAGE Could not find bundle: org.eclipse.equinox.console
!STACK 0
org.osgi.framework.BundleException: Could not find bundle: org.eclipse.equinox.console
at org.eclipse.osgi.framework.internal.core.ConsoleManager.checkForConsoleBundle(ConsoleManager.java:211)
at org.eclipse.core.runtime.adaptor.EclipseStarter.startup(EclipseStarter.java:298)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:177)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Starting application: 1133
Fri Feb 22 20:37:47 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867262 ms) in thread [main]:
LogLevel(WARNING), Message(riena.core is not started. This may probably not work.)
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=73} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=74} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867212 ms) in thread [main]:
LogLevel(INFO), Message(No configuration given!.)
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867262 ms) in thread [main]:
LogLevel(INFO), Message(found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.RemoteServiceFactoryHessian@1ce669e)
Fri Feb 22 20:37:47 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867272 ms) in thread [main]:
LogLevel(DEBUG), Message(OSGi NEW service registered id: org.eclipse.riena.monitor.common.IReceiver)
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.core.util.ContainerModel DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
LogLevel(INFO), Message(!!! Riena is running in CLIENT mode !!!)
Fri Feb 22 20:37:47 CET 2013 DEBUG [Worker-0] org.eclipse.riena.core.cache.GenericObjectCache DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
LogLevel(DEBUG), Message(creating new GenericObjectCache instance)
LogLevel(DEBUG), Message(setTimeout = 60000)
LogLevel(DEBUG), Message(setMinSize = 1)
LogLevel(DEBUG), Message(setTimeout = 999999000)
Fri Feb 22 20:37:47 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
Fri Feb 22 20:37:47 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867292 ms) in thread [main]:
LogLevel(DEBUG), Message(OSGi NEW service registered id: org.eclipse.riena.security.common.authentication.IAuthenticationService)
Fri Feb 22 20:37:47 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 20:37:47 CET 2013 (1361561867282 ms) in thread [main]:
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.Activator$StartupBundleListener Riena is running in stage '<unknown>'.
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=75} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=76} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.security.ui' succesful.
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.ui.ridgets.swt.optional' succesful.
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache put = DummyPrincipal , java.security.Permissions@d480ea (
(java.lang.RuntimePermission navi)
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache processQueue
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Platform Instance Location: file:/C:/Users/TalayE1/Desktop/Software/EclipseWorkspace/runtime-New_configuration/
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Found directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client is not a directory.
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Created instance area directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigation.subapplication, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigate.form, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.sharedViews, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.uiProcesses, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.playground, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.filters, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.logcollector, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache get = DummyPrincipal
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.mgkundennummer[level=MODULEGROUP sequence=1]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.mgkundennummer, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.exceptiontest.mg[level=MODULEGROUP sequence=1]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.exceptiontest.mg, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.subModule.contentFilter[level=SUBMODULE sequence=1]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.subModule.contentFilter, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.activatedeactivate.mg[level=MODULEGROUP sequence=2]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.activatedeactivate.mg, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module onePersonSubModule[level=SUBMODULE sequence=2]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=onePersonSubModule, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.selectablesubmodule.modulegroup[level=MODULEGROUP sequence=100]
Fri Feb 22 20:37:47 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.selectablesubmodule.modulegroup, instanceId=null]
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client\simplestore
Fri Feb 22 20:37:47 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore in development mode, trying to clean-up store.
Fri Feb 22 20:37:47 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=77} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=78} ServiceEvent REGISTERED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.monitor.client' succesful.
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 20:37:47 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Fri Feb 22 20:37:48 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=79} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=80} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=81} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=82} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=83} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=84} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=85} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=86} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=87} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=88} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=89} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=90} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=91} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=92} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=93} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=94} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=95} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=96} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=97} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=98} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=99} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/HandlerContainer/handlers/*], service.id=100} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=101} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=2147483647, service.id=102} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=103} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=104} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=105} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=106} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.eclipse.ui.IWorkbench}={service.id=107} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=108} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=109} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=110} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=111} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=112} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=113} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=114} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=115} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=116} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=117} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/*], service.id=118} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=119} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=120} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=121} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=122} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=123} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Contribution/object/*], service.id=124} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/GenericTile/horizontal/*], service.id=125} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/containerData/*], service.id=126} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=127} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=128} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=129} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=130} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=131} ServiceEvent REGISTERED
Fri Feb 22 20:37:48 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=132} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=133} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=134} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=135} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=136} ServiceEvent REGISTERED
Fri Feb 22 20:37:49 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=137} ServiceEvent REGISTERED
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-02-22 20:37:49.310
!MESSAGE Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!STACK 0
at org.eclipse.riena.navigation.ui.controllers.ApplicationController.updateLabel(ApplicationController.java:117)
at org.eclipse.riena.navigation.ui.controllers.ApplicationController.afterBind(ApplicationController.java:112)
at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdvisor.doInitialBinding(ApplicationViewAdvisor.java:392)
at org.eclipse.riena.navigation.ui.swt.views.ApplicationViewAdvisor.postWindowOpen(ApplicationViewAdvisor.java:242)
at org.eclipse.ui.internal.WorkbenchWindow.fireWindowOpened(WorkbenchWindow.java:1229)
at org.eclipse.ui.internal.Workbench.createWorkbenchWindow(Workbench.java:1264)
at org.eclipse.ui.internal.Workbench.getActiveWorkbenchWindow(Workbench.java:1225)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.updateActiveShell(WorkbenchSourceProvider.java:924)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider.getCurrentState(WorkbenchSourceProvider.java:133)
at org.eclipse.ui.internal.services.WorkbenchSourceProvider$6.handleEvent(WorkbenchSourceProvider.java:684)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1058)
at org.eclipse.swt.widgets.Decorations.WM_ACTIVATE(Decorations.java:1664)
at org.eclipse.swt.widgets.Shell.WM_ACTIVATE(Shell.java:2145)
at org.eclipse.swt.widgets.Control.windowProc(Control.java:4525)
at org.eclipse.swt.widgets.Canvas.windowProc(Canvas.java:340)
at org.eclipse.swt.widgets.Decorations.windowProc(Decorations.java:1627)
at org.eclipse.swt.widgets.Shell.windowProc(Shell.java:2069)
at org.eclipse.swt.widgets.Display.windowProc(Display.java:4976)
at org.eclipse.swt.internal.win32.OS.BringWindowToTop(Native Method)
at org.eclipse.swt.widgets.Decorations.bringToTop(Decorations.java:231)
at org.eclipse.swt.widgets.Shell.open(Shell.java:1217)
at org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer.postProcess(WBWRenderer.java:735)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:643)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:729)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:694)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:679)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:982)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:941)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:79)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.riena.navigation.ui.swt.application.SwtApplication.createView(SwtApplication.java:69)
at org.eclipse.riena.navigation.ui.application.AbstractApplication.start(AbstractApplication.java:70)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:354)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:181)
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) started without retry
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) started without retry
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) ended (nothing to send)
Fri Feb 22 20:37:52 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) ended (nothing to send)
Fri Feb 22 20:38:02 CET 2013 DEBUG [Worker-4] org.eclipse.riena.monitor.client.SimpleStore Store Cleaner started
Fri Feb 22 20:38:02 CET 2013 DEBUG [Worker-4] org.eclipse.riena.monitor.client.SimpleStore Store Cleaner ended
Fri Feb 22 20:37:49 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@70c242 Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-22 20:38:36.882
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@1b104d7 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@f8ae79, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 175, y: 215, width: 1024, height: 768)
!STACK 0
!ENTRY org.eclipse.riena.core 4 0 2013-02-22 20:38:36.894
!MESSAGE exception handler class org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox#handleException() throws an exception
!STACK 0
at org.eclipse.riena.ui.swt.MessageBox.show(MessageBox.java:82)
at org.eclipse.riena.internal.ui.ridgets.swt.MessageBoxRidget.show(MessageBoxRidget.java:91)
at org.eclipse.riena.internal.ui.ridgets.swt.MessageBoxRidget.show(MessageBoxRidget.java:83)
at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox.showMessageBox(ExceptionMessageBox.java:66)
at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox.access$0(ExceptionMessageBox.java:51)
at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox$1.run(ExceptionMessageBox.java:39)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer$SyncExecutor.execute(SwtUISynchronizer.java:245)
at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer.executeOnDisplay(SwtUISynchronizer.java:195)
at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer.execute(SwtUISynchronizer.java:77)
at org.eclipse.riena.ui.swt.uiprocess.SwtUISynchronizer.syncExec(SwtUISynchronizer.java:55)
at org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox.handleException(ExceptionMessageBox.java:36)
at org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager.handleException(SimpleExceptionHandlerManager.java:105)
at org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager.handleException(SimpleExceptionHandlerManager.java:99)
at org.eclipse.riena.navigation.ui.swt.views.ApplicationAdvisor$1.handle(ApplicationAdvisor.java:75)
at org.eclipse.ui.internal.WorkbenchErrorHandlerProxy.handle(WorkbenchErrorHandlerProxy.java:36)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:189)
at org.eclipse.ui.statushandlers.StatusManager.handle(StatusManager.java:231)
at org.eclipse.ui.statushandlers.StatusManager$StatusManagerLogListener.logging(StatusManager.java:305)
at org.eclipse.core.internal.runtime.RuntimeLog.logToListeners(RuntimeLog.java:160)
at org.eclipse.core.internal.runtime.PlatformLogWriter.logged(PlatformLogWriter.java:100)
at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.safeLogged(ExtendedLogReaderServiceFactory.java:86)
at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.logPrivileged(ExtendedLogReaderServiceFactory.java:205)
at org.eclipse.equinox.log.internal.ExtendedLogReaderServiceFactory.log(ExtendedLogReaderServiceFactory.java:178)
at org.eclipse.equinox.log.internal.ExtendedLogServiceFactory.log(ExtendedLogServiceFactory.java:65)
at org.eclipse.equinox.log.internal.ExtendedLogServiceImpl.log(ExtendedLogServiceImpl.java:87)
at org.eclipse.equinox.log.internal.LoggerImpl.log(LoggerImpl.java:54)
at org.eclipse.core.runtime.internal.adaptor.EclipseLogFactory$1.log(EclipseLogFactory.java:53)
at org.eclipse.e4.ui.internal.workbench.WorkbenchLogger.log(WorkbenchLogger.java:111)
at org.eclipse.e4.ui.internal.workbench.WorkbenchLogger.error(WorkbenchLogger.java:52)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.handleException(PartRenderingEngine.java:688)
at org.eclipse.core.runtime.SafeRunner.handleException(SafeRunner.java:75)
at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:44)
Fri Feb 22 20:38:36 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager exception handler class org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox#handleException() throws an exception
!STACK 0
Fri Feb 22 20:38:36 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@1b104d7 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@f8ae79, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 175, y: 215, width: 1024, height: 768)
at org.eclipse.equinox.internal.app.EclipseAppHandle.run(
| Re: Eclipse package for Riena [message #1013156 is a reply to message #1013102] |
Fri, 22 February 2013 17:50   |
Junior Member |
1.
I could solve now one of the problems:
"!MESSAGE Could not find bundle: org.eclipse.equinox.console"
by adding some more bundles
-org.apache.felix.gogo.command
-org.apache.felix.gogo.runtime
-org.apache.felix.gogo.shell
-org.eclipse.equinox.console
2.
Secondly I have changed the SWT 4.3 plugin by the 4.2.1.
There are still some errors...
Configuration location:
file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/
Configuration file:
file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/config.ini loaded
Install location:
file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/
Framework located:
file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/.bundle_pool/plugins/org.eclipse.osgi_3.9.0.v20130128-202223.jar
Framework classpath:
Splash location:
C:\Users\***\Desktop\Software\EclipseWorkspace\kepler\org.eclipse.riena.example.client\splash.bmp
Debug options:
file:/C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/.options loaded
Time to load bundles: 350
Starting application: 1200
osgi> Fri Feb 22 23:44:50 CET 2013 INFO [main] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=95} ServiceEvent REGISTERED
Fri Feb 22 23:44:50 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=96} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090850 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090800 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090850 ms) in thread [main]:
LogLevel(INFO), Message(found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.RemoteServiceFactoryHessian@18e8541)
Fri Feb 22 23:44:51 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090860 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.core.util.ContainerModel DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 DEBUG [Worker-0] org.eclipse.riena.core.cache.GenericObjectCache DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=97} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.Activator$StartupBundleListener Riena is running in stage '<unknown>'.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=98} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.security.ui' succesful.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.equinox.log' succesful.
Fri Feb 22 23:44:51 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Fri Feb 22 23:44:50 CET 2013 (1361573090870 ms) in thread [main]:
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.ui.ridgets.swt.optional' succesful.
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Platform Instance Location: file:/C:/Users/TalayE1/Desktop/Software/EclipseWorkspace/runtime-New_configuration/
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Found directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client is not a directory.
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.core.RienaLocations Created instance area directory at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache put = DummyPrincipal , java.security.Permissions@1be8711 (
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache processQueue
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigation.subapplication, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigate.form, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.sharedViews, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.uiProcesses, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.playground, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.filters, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.logcollector, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache get = DummyPrincipal
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.mgkundennummer[level=MODULEGROUP sequence=1]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.mgkundennummer, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.exceptiontest.mg[level=MODULEGROUP sequence=1]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.exceptiontest.mg, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.subModule.contentFilter[level=SUBMODULE sequence=1]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.subModule.contentFilter, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.activatedeactivate.mg[level=MODULEGROUP sequence=2]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.activatedeactivate.mg, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module onePersonSubModule[level=SUBMODULE sequence=2]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=onePersonSubModule, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.selectablesubmodule.modulegroup[level=MODULEGROUP sequence=100]
Fri Feb 22 23:44:51 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.selectablesubmodule.modulegroup, instanceId=null]
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore at C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\runtime-New_configuration\org.eclipse.riena.monitor.client\simplestore
Fri Feb 22 23:44:51 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore in development mode, trying to clean-up store.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=99} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.monitor.client' succesful.
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 23:44:51 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=100} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=101} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=102} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=103} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=104} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=105} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=106} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=107} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=108} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=109} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=110} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=111} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=112} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=113} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=114} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=115} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=116} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=117} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=118} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=119} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=120} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=121} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/HandlerContainer/handlers/*], service.id=122} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=123} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=2147483647, service.id=124} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=125} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=126} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=127} ServiceEvent REGISTERED
Fri Feb 22 23:44:51 CET 2013 INFO [Thread-3] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=128} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.eclipse.ui.IWorkbench}={service.id=129} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=130} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=131} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=132} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=133} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=134} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=135} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=136} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=137} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=138} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=139} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/*], service.id=140} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=141} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=142} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=143} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=144} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=145} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Contribution/object/*], service.id=146} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/GenericTile/horizontal/*], service.id=147} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/containerData/*], service.id=148} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=149} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=150} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=151} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=152} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=153} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=154} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UILabel/*], service.id=155} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/selected/*], service.id=156} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/menu/Item/enabled/*], service.id=157} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/*], service.id=158} ServiceEvent REGISTERED
Fri Feb 22 23:44:52 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=159} ServiceEvent REGISTERED
!SESSION 2013-02-22 23:44:49.559 -----------------------------------------------
Command-line arguments: -application org.eclipse.riena.example.client.exampleapp -data C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\kepler/../runtime-New_configuration -dev file:C:/Users/TalayE1/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication/dev.properties -debug C:\Users\TalayE1\Desktop\Software\EclipseWorkspace\kepler\.metadata\.plugins\org.eclipse.pde.core\SWT ExampleApplication/.options -os win32 -ws win32 -arch x86 -clean -console -consolelog
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-02-22 23:44:52.692
!STACK 0
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) started without retry
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) started without retry
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-2] org.eclipse.riena.monitor.client.SimpleSender Sender(LogCollector) ended (nothing to send)
Fri Feb 22 23:44:56 CET 2013 DEBUG [Worker-3] org.eclipse.riena.monitor.client.SimpleSender Sender(CustomCollector) ended (nothing to send)
Fri Feb 22 23:44:52 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@fe0ce9 Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-22 23:44:56.693
!MESSAGE Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@f6398 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@dbbe8b, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 200, y: 240, width: 1024, height: 768)
!STACK 0
!ENTRY org.eclipse.riena.core 4 0 2013-02-22 23:44:56.693
!STACK 0
Fri Feb 22 23:44:56 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager exception handler class org.eclipse.riena.example.client.exceptionhandler.ExceptionMessageBox#handleException() throws an exception
!STACK 0
Fri Feb 22 23:44:56 CET 2013 ERROR [main] org.eclipse.riena.internal.core.exceptionmanager.SimpleExceptionHandlerManager Exception occurred while rendering: org.eclipse.e4.ui.model.application.ui.basic.impl.TrimmedWindowImpl@f6398 (elementId: IDEWindow, tags: [topLevel], contributorURI: platform:/plugin/org.eclipse.ui.workbench) (widget: Shell {Example & Playground - 5.0.0.v20130204_5_0_0_M5}, renderer: org.eclipse.e4.ui.workbench.renderers.swt.WBWRenderer@dbbe8b, toBeRendered: true, onTop: false, visible: true, containerData: null, accessibilityPhrase: null) (label: null, iconURI: null, tooltip: null, context: TrimmedWindowImpl (IDEWindow) Context, variables: [], x: 200, y: 240, width: 1024, height: 768)
at sun.reflect.NativeMethodAccessorImpl.invoke(Unknown
| Re: Eclipse package for Riena [message #1014487 is a reply to message #1014357] |
Mon, 25 February 2013 17:46   |
Junior Member |
Hello Jordan,
many thanks for the hints!
I started with completely new eclipse installation.
1. Unpack eclipse-SDK-4.3M5a-win32.zip
2. Create a target platform rienaE4 with the right E4 plugins (Screen shot)
3. Create a source project from plugin org.eclipse.riena.example.client
4. Add required plugins for launch configuration SWT ExampleApplication E4.launch
--> The example project itself is now error free.
==> But there are still some problems by starting the example project.
Thx!
Max
Mon Feb 25 23:27:54 CET 2013 INFO [Start Level Event Dispatcher] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=78} ServiceEvent REGISTERED
Mon Feb 25 23:27:54 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274824 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Start Level Event Dispatcher] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=79} ServiceEvent REGISTERED
Mon Feb 25 23:27:54 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.Activator$StartupBundleListener Riena is running in stage '<unknown>'.
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274777 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274824 ms) in thread [Start Level Event Dispatcher]:
LogLevel(INFO), Message(found protocol [hessian] org.eclipse.riena.internal.communication.factory.hessian.RemoteServiceFactoryHessian@89cc5e)
Mon Feb 25 23:27:54 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274824 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.core.util.ContainerModel DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 DEBUG [Worker-0] org.eclipse.riena.core.cache.GenericObjectCache DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 INFO [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 DEBUG [Worker-0] org.eclipse.riena.internal.communication.core.registry.RemoteServiceRegistry DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
Mon Feb 25 23:27:54 CET 2013 WARNING [Worker-0] org.eclipse.riena.communication.core.factory.RemoteServiceFactory DeferredLogEvent on Mon Feb 25 23:27:54 CET 2013 (1361831274839 ms) in thread [Start Level Event Dispatcher]:
LogLevel(WARNING), Message(riena.core is not started. This may probably not work.)
Mon Feb 25 23:27:54 CET 2013 DEBUG [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup: 'org.eclipse.riena.security.ui' is already ACTIVE.
Mon Feb 25 23:27:54 CET 2013 WARNING [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup required bundle: 'org.eclipse.equinox.log' not found.
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations Platform Instance Location: file:/C:/Users/***/Desktop/Software/EclipseWorkspace/runtime-org.eclipse.riena.navigation.ui.e4.product/
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations Found directory at C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\org.eclipse.riena.monitor.client is not a directory.
Mon Feb 25 23:27:54 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.core.RienaLocations Created instance area directory at C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\org.eclipse.riena.monitor.client
Mon Feb 25 23:27:55 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore at C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\org.eclipse.riena.monitor.client\simplestore
Mon Feb 25 23:27:55 CET 2013 DEBUG [Start Level Event Dispatcher] org.eclipse.riena.monitor.client.SimpleStore SimpleStore in development mode, trying to clean-up store.
Mon Feb 25 23:27:55 CET 2013 INFO [Start Level Event Dispatcher] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=80} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] org.eclipse.riena.internal.core.StartupsSafeRunnable Startup <<lazy>>: 'org.eclipse.riena.monitor.client' succesful.
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent STARTED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent STARTLEVEL CHANGED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[comp,component,dis,disAll,disable,disableAll,en,enAll,enable,enableAll,list,ls], osgi.command.scope=equinox, service.id=81} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[ns,pt], osgi.command.scope=equinox, service.id=82} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[activeApps,apps,lockApp,schedApp,startApp,stopApp,unlockApp,unschedApp], osgi.command.scope=equinox, service.id=83} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[controlstats], osgi.command.scope=equinox, service.id=84} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[logLevel], osgi.command.scope=equinox, service.id=85} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.command.Converter}={service.id=86} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.EquinoxCommandProvider}={service.ranking=2147483647, osgi.command.function=[exit,shutdown,sta,start,sto,stop,i,install,up,up,up,update,update,update,un,uninstall,s,status,se,services,p,p,packages,packages,bundles,b,bundle,gc,init,close,r,refresh,exec,fork,h,headers,pr,props,setp,setprop,ss,t,threads,sl,setfwsl,setbsl,setibsl,requiredBundles,classSpaces,profilelog,getPackages,getprop,diag,enableBundle,disableBundle,disabledBundles], osgi.command.scope=equinox, service.id=87} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.HelpCommand}={service.ranking=2147483647, osgi.command.function=[help], osgi.command.scope=equinox, service.id=88} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.ManCommand}={osgi.command.function=[man], osgi.command.scope=equinox, service.id=89} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.commands.DisconnectCommand}={osgi.command.function=[disconnect], osgi.command.scope=equinox, service.id=90} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.threadio.ThreadIO}={service.id=91} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.equinox.console.telnet.TelnetCommand}={osgi.command.function=[telnet], osgi.command.scope=equinox, service.id=93} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.command.CommandProcessor}={service.id=92} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.service.command.Converter}={service.id=94} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Builtin}={osgi.command.function=[format,getopt,new,set,tac,type], osgi.command.scope=gogo, service.id=95} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Procedural}={osgi.command.function=[each,if,not,throw,try,until,while], osgi.command.scope=gogo, service.id=96} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Posix}={osgi.command.function=[cat,echo,grep], osgi.command.scope=gogo, service.id=97} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Telnet}={osgi.command.function=[telnetd], osgi.command.scope=gogo, service.id=98} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.apache.felix.gogo.shell.Shell}={osgi.command.function=[gosh,sh,source], osgi.command.scope=gogo, service.id=99} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.ApplicationLauncher}={service.id=100} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [Framework Event Dispatcher] null FrameworkEvent INFO
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=101} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=102} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=103} ServiceEvent REGISTERED
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache put = DummyPrincipal , java.security.Permissions@eb67e8 (
(java.lang.RuntimePermission navi)
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache processQueue
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigation.subapplication, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.navigate.form, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.sharedViews, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.uiProcesses, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.playground, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.filters, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.logcollector, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.core.cache.GenericObjectCache get = DummyPrincipal
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.mgkundennummer[level=MODULEGROUP sequence=1]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.mgkundennummer, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.exceptiontest.mg[level=MODULEGROUP sequence=1]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.exceptiontest.mg, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.client.subModule.contentFilter[level=SUBMODULE sequence=1]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.client.subModule.contentFilter, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.activatedeactivate.mg[level=MODULEGROUP sequence=2]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.activatedeactivate.mg, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module onePersonSubModule[level=SUBMODULE sequence=2]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=onePersonSubModule, instanceId=null]
Mon Feb 25 23:27:55 CET 2013 INFO [main] org.eclipse.riena.navigation.ui.application.AbstractApplication creating startup module org.eclipse.riena.example.selectablesubmodule.modulegroup[level=MODULEGROUP sequence=100]
Mon Feb 25 23:27:55 CET 2013 DEBUG [main] org.eclipse.riena.navigation.model.AbstractSimpleNavigationNodeProvider createNode: NavigationNodeId [typeId=org.eclipse.riena.example.selectablesubmodule.modulegroup, instanceId=null]
Mon Feb 25 23:27:56 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STARTED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=104} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=105} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=106} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=107} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=108} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=109} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=110} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=111} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=112} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=113} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=114} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=115} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=116} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=117} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=118} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=119} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=120} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=121} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=122} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=123} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=124} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=125} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=126} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=127} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=128} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=129} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=130} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=131} ServiceEvent REGISTERED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=132} ServiceEvent REGISTERED
!SESSION 2013-02-25 23:27:54.028 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_23
BootLoader constants: OS=win32, ARCH=x86, WS=win32, NL=de_DE
Framework arguments: -product org.eclipse.riena.e4.launcher.product
Command-line arguments: -product org.eclipse.riena.e4.launcher.product -data C:\Users\***\Desktop\Software\EclipseWorkspace\kepler/../runtime-org.eclipse.riena.navigation.ui.e4.product -dev file:C:/Users/***/Desktop/Software/EclipseWorkspace/kepler/.metadata/.plugins/org.eclipse.pde.core/SWT ExampleApplication E4/dev.properties -os win32 -ws win32 -arch x86 -consoleLog
!ENTRY org.eclipse.e4.ui.workbench.swt 4 2 2013-02-25 23:27:56.339
!STACK 0
java.lang.ExceptionInInitializerError
at org.eclipse.riena.ui.swt.utils.UIControlsFactory.createInfoFlyout(UIControlsFactory.java:764)
at org.eclipse.riena.e4.launcher.rendering.ApplicationView.createInfoFlyout(ApplicationView.java:169)
at org.eclipse.riena.e4.launcher.rendering.RienaWBWRenderer.rienaCreateContents(RienaWBWRenderer.java:579)
at org.eclipse.riena.e4.launcher.rendering.RienaWBWRenderer.createWidget(RienaWBWRenderer.java:452)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:893)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:627)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:636)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:591)
at org.eclipse.equinox.launcher.Main.run(Main.java:1450)
at org.eclipse.equinox.launcher.Main.main(Main.java:1426)
Caused by: java.lang.RuntimeException: Could not load org.eclipse.riena.ui.swt.facades.SWTFacadeRCP
at org.eclipse.riena.ui.swt.facades.FacadeFactory.newFacade(FacadeFactory.java:53)
at org.eclipse.riena.ui.swt.facades.SWTFacade.<clinit>(SWTFacade.java:47)
... 29 more
Caused by: java.lang.ClassNotFoundException: org.eclipse.riena.ui.swt.facades.SWTFacadeRCP
at org.eclipse.osgi.internal.loader.BundleLoader.findClassInternal(BundleLoader.java:501)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:421)
at org.eclipse.osgi.internal.loader.BundleLoader.findClass(BundleLoader.java:412)
at org.eclipse.osgi.internal.baseadaptor.DefaultClassLoader.loadClass(DefaultClassLoader.java:107)
at org.eclipse.riena.ui.swt.facades.FacadeFactory.newFacade(FacadeFactory.java:46)
... 30 more
Mon Feb 25 23:27:56 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@141b736 Problems occurred when invoking code from plug-in: "org.eclipse.e4.ui.workbench.swt".
... 29 more
... 30 more
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=STOPPING, eclipse.application.type=main.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application.0, application.descriptor=org.eclipse.e4.ui.workbench.swt.E4Application, service.id=63} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=org.eclipse.equinox.app.stopped, eclipse.application.type=main.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application.0, application.descriptor=org.eclipse.e4.ui.workbench.swt.E4Application, service.id=63} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=, application.visible=false, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.equinox.app.error, application.launchable=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.equinox.app_1.3.100.v20120522-1841.jar, service.id=61} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=Internal Model Topic Generator, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.e4.ui.workbench.swt.GenTopic, application.launchable=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.0.v20130124-145547.jar, service.id=60} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=E4 Application, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application, application.launchable=true, eclipse.application.default=true, application.locked=false, application.location=initial@reference:file:plugins/org.eclipse.e4.ui.workbench.swt_0.12.0.v20130124-145547.jar, service.id=59} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 DEBUG [main] null {org.osgi.service.application.ApplicationDescriptor}={eclipse.application.type=main.thread, application.name=org.eclipse.riena.example.client.application, application.visible=true, application.container=org.eclipse.equinox.app, service.pid=org.eclipse.riena.example.client.exampleapp, application.launchable=true, application.locked=false, application.location=initial@reference:file:../../../../org.eclipse.riena.example.client/, service.id=62} ServiceEvent MODIFIED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.application.ApplicationHandle, org.eclipse.equinox.app.IApplicationContext}={application.state=org.eclipse.equinox.app.stopped, eclipse.application.type=main.thread, application.supports.exitvalue=true, eclipse.application.default=true, service.pid=org.eclipse.e4.ui.workbench.swt.E4Application.0, application.descriptor=org.eclipse.e4.ui.workbench.swt.E4Application, service.id=63} ServiceEvent UNREGISTERING
!ENTRY org.eclipse.osgi 4 0 2013-02-25 23:27:56.355
!MESSAGE Application error
!STACK 1
... 29 more
... 30 more
Mon Feb 25 23:27:56 CET 2013 ERROR [main] org.eclipse.equinox.logger org.eclipse.osgi.framework.log.FrameworkLogEntry@508be Application error
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:729)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:700)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:694)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:679)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:982)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:941)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:79)
... 29 more
... 30 more
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.ApplicationLauncher}={service.id=100} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.osgi.service.runnable.StartupMonitor}={service.ranking=-2147483648, service.id=1} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=131} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=132} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=126} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=124} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/Context/context/*], service.id=113} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=125} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=127} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perspOpened], service.id=123} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/selectedElement/*], service.id=119} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/LifeCycle/perpSaved], service.id=122} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/TrimmedWindow/trimBars/*], service.id=130} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=117} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=118} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTableContainer/bindingTables/*], service.id=107} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingTable/bindings/*], service.id=108} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/command/*], service.id=109} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeyBinding/parameters/*], service.id=110} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/KeySequence/keySequence/*], service.id=111} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=112} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/ElementContainer/children/*], service.id=114} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/commands/BindingContext/children/*], service.id=106} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/basic/Window/windows/*], service.id=128} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/advanced/Perspective/windows/*], service.id=129} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/widget/*], service.id=101} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/visible/*], service.id=116} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/commands/*], service.id=104} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/Application/categories/*], service.id=105} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/elementId/*], service.id=121} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/ui/UIElement/toBeRendered/*], service.id=115} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.osgi.service.event.EventHandler}={event.topics=[org/eclipse/e4/ui/model/application/ApplicationElement/tags/*], service.id=120} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [Framework Event Dispatcher] null BundleEvent STOPPED
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.monitor.common.IReceiver}={service.url=ttp://localhost:8080/hessian/CollectibleReceiverWS, service.protocol=hessian, service.id=68} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.authentication.IAuthenticationService}={service.url=ttp://localhost:8080/hessian/AuthenticationService, service.protocol=hessian, service.id=74} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.internal.navigation.ui.filter.IUIFilterApplier}={service.id=79} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=-100, service.id=103} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {java.lang.Object}={osgi.command.function=[controlstats], osgi.command.scope=equinox, service.id=84} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.osgi.framework.console.CommandProvider}={service.id=75} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.ui.testing.TestableObject}={component.name=org.eclipse.ui.testing.TestableObject, component.id=0, service.id=35} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.e4.core.contexts.IContextFunction}={service.context.key=org.eclipse.e4.core.services.statusreporter.StatusReporter, component.name=org.eclipse.e4.ui.workbench.swt.statusReporter, component.id=1, service.id=36} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.e4.core.contexts.IContextFunction}={service.context.key=org.eclipse.e4.ui.workbench.swt.modeling.EMenuService, component.name=org.eclipse.e4.ui.workbench.swt.menuService, component.id=2, service.id=37} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.monitor.client.IAggregator}={service.ranking=-100, service.id=80} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.session.ISessionHolder}={service.id=69} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.hooks.ICallHook}={service.id=70} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.ISubjectHolder}={service.id=71} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.authorization.IPermissionCache}={service.ranking=-100, service.id=72} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.security.common.authorization.ISentinelService}={service.ranking=-100, service.id=73} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.ui.workarea.spi.IWorkareaDefinitionRegistry}={service.ranking=100, service.id=102} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.ui.filter.IUIFilterProvider}={service.ranking=-100, service.id=78} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] org.eclipse.riena.internal.communication.core.ssl.SSLConfiguration No configuration given!.
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.IRemoteServiceRegistry}={service.ranking=-100, service.id=65} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.hooks.ICallHook}={service.id=66} ServiceEvent UNREGISTERING
Mon Feb 25 23:27:56 CET 2013 INFO [main] null {org.eclipse.riena.communication.core.progressmonitor.IRemoteProgressMonitorRegistry}={service.id=67} ServiceEvent UNREGISTERING
An error has occurred. See the log file
C:\Users\***\Desktop\Software\EclipseWorkspace\runtime-org.eclipse.riena.navigation.ui.e4.product\.metadata\.log.
| Re: Eclipse package for Riena [message #1015339 is a reply to message #1015327] |
Thu, 28 February 2013 04:35  |
Jordan Dukadinov Messages: 9 Registered: July 2009 Location: Germany |
Junior Member |
Hi Max,
in the step where you "add required plug-ins" to the launch configuration, also check the "include optional dependencies" checkbox below the bundles list.
5:28 in your screencast.
Jordan
Current Time: Tue May 21 01:33:28 EDT 2013
Powered by FUDForum. Page generated in 0.02306 seconds
