Home » Eclipse Projects » Remote Application Platform (RAP) » How to have single sourcing ?
icon5.gif  How to have single sourcing ? [message #1015295] Thu, 28 February 2013 01:22 Go to next message
Vikas K is currently offline Vikas K
We are porting an existing rcp app to web using rap and trying to have the single source for both RCP and RAP. We couldn't achieve it without modifying the existing Manifest files(having rcp related dependencies) and overriding them with new dependencies(rap related dependencies). So Is there any way to achieve it without modifying the existing Manifest files??
Re: How to have single sourcing ? [message #1015312 is a reply to message #1015295] Thu, 28 February 2013 03:10 Go to previous messageGo to next message
Tiburon T is currently offline Tiburon T
Member
I think it is possible to keep both dependencies by making them optional.
Greetings
Tiburon
Re: How to have single sourcing ? [message #1015548 is a reply to message #1015312] Fri, 01 March 2013 03:44 Go to previous messageGo to next message
Hi Tiburon
Thanks for the reply. We can make it optional in our plugins, but we are using few third party plugins. Is there any possibility to override the existing required plugin dependencies for the third party plugins??
We tried with fragments also, but we are unable to override the existing dependencies in the third party plugin.
Re: How to have single sourcing ? [message #1015699 is a reply to message #1015548] Fri, 01 March 2013 14:40 Go to previous message
Paul Bilnoski is currently offline Paul Bilnoski
Something our shop has used with some success are "shim" bundles that expose the functionality and namespace of the org.eclipse.ui bundles, but by reexporting the org.eclipse.rap.ui bundles. The problem with using package imports, as we would prefer, with the org.eclipse.ui namespace is that they have packages split across several bundles, so bundle import is the only clean option.
The concept of these shims is to make an empty bundle (no sources) with reexported dependencies, i.e. only a manifest and build.properties. These reexport RAP 1.5 as eclipse 3.7, so if you are using other versions take care to map them properly.
By dropping these shim bundles in your target platform, the dependencies should resolve properly to RAP. Keep in mind you may need to rebuild the code to ensure all API dependencies are met, since RAP is not an exact replacement and might not be binary-compatible with bundles built against the true org.eclipse.ui bundles.
Here are two example bundle manifest files:
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Eclipse RAP UI Proxy
Bundle-SymbolicName: org.eclipse.ui
Bundle-Version: 3.7.0.qualifier
Bundle-RequiredExecutionEnvironment: JavaSE-1.6
Require-Bundle: org.eclipse.rap.ui;bundle-version="1.5.0";visibility:=reexport,
 org.eclipse.swt;bundle-version="3.7.0";visibility:=reexport,
 org.eclipse.jface;bundle-version="3.7.0";visibility:=reexport,
 org.eclipse.ui.workbench;bundle-version="3.7.0";visibility:=reexport
Bundle-Name: Eclipse RAP Workbench Proxy
Bundle-SymbolicName: org.eclipse.ui.workbench
Require-Bundle: org.eclipse.rap.ui.workbench;bundle-version="1.5.0";visibility:=reexport,
--Paul
Previous Topic:Prompting User for Unsaved data
Next Topic:Difficulties getting started with RAP 2.0
Current Time: Thu May 23 06:40:42 EDT 2013
Powered by FUDForum. Page generated in 0.01828 seconds
