| Failed to load JNI library [message #1014936] |
Tue, 26 February 2013 16:21  |
rafy avades Messages: 1 Registered: February 2013 |
Junior Member |
I've just installed Eclipse on my new machine.
64-bit version, with 64-bit Java, 64-big JDK and 64-big JVM.
I've read here: http://wiki.eclipse.org/Eclipse.ini
However, my Eclipse.ini is all on one line like so:
-startup
plugins/org.eclipse.equinox.launcher_1.3.0.v20120522-1813.jar
--launcher.library
plugins/org.eclipse.equinox.launcher.win32.win32.x86_64_1.1.200.v20120522-1813
-product
org.eclipse.epp.package.jee.product
--launcher.defaultAction
openFile
--launcher.XXMaxPermSize
256M
-showsplash
org.eclipse.platform
256m
openFile
-vmargs
C:\Program Files\Java\jre7\bin\javaw.exe
-Dosgi.requiredJavaVersion=1.5
-Dhelp.lucene.tokenizer=standard
-Xms40m
-Xmx512m
When saving, it says "Access is denied" I am the admin on this account, I am the only user account on this PC.
Does the above ini file look okay? That is where my javaw.exe is installed.
| Re: Failed to load JNI library [message #1015242 is a reply to message #1014936] |
Wed, 27 February 2013 16:01   |
Russell Bateman Messages: 2711 Registered: July 2009 Location: Provo, Utah, USA |
> -startup
> --launcher.library
> -product
> openFile
> 256M
> -showsplash
> 256m
> openFile
> -vmargs
> -Xms40m
> -Xmx512m
Rafy,
Squint harder at the eclipse.ini doc. You should instead have:
-vm
-vmargs
Also, if you're going to develop in Java, you might just as well change
that path to point at an actual JDK (and not merely a JRE) because
you'll need it. However, you can point at your JDK via Window -> Java ->
Installed JREs whatever JRE is running Eclipse for you.
Hope this helps. Best of luck.
| Re: Failed to load JNI library [message #1016656 is a reply to message #1016567] |
Thu, 07 March 2013 04:34   |
D Wojee Messages: 3 Registered: March 2013 |
Junior Member |
I did instal the 64 bit win8 but apparently java doesnt install as 64-bit, which is frustrating since I am using Waterfox, a 64bit browser. Even my system information shows the 64-bit info.
This is from the Java FAQ:
Why do I only get the 32-bit Java when I go to Java.com?
Java.com provides a Java version based on your browser and operating system (OS). If you are running a 64-bit version of Windows 8, you have access to 32-bit and 64-bit versions of Internet Explorer 10 on your system. The desktop version of the Windows 8 OS does not run in a full 64-bit mode (unless you have Enhanced Protected Mode in Internet Explorer 10 turned on), thus 32-bit Java is the default.
Quite obvious to me that Java did not read my system or browser correctly, but yet will not let me download or install a 64 bit version of it. We have a word for this kind of behavior in the gaming community - lame.
After more digging I found the right java version, seems the auto install just doesnt work right so have to download and install java, as they call it, offline mode.
And with that fixed, we have a winner. thanks
[Updated on: Thu, 07 March 2013 05:09] Report message to a moderator
| Re: Failed to load JNI library [message #1016777 is a reply to message #1016656] |
Thu, 07 March 2013 11:39   |
> This is from the FAQ:
> Quote:
> - lame.
> So other than being forced to use the 32 bit of eclipse for modeling,
> any suggestions?
This is surprising to me, but then I don't do Windoz. So, you're saying
that no 64-bit Java will install on Windows 8? Radically surprising! No
wonder when W8 came out I told my wife she's headed next to Macintosh
(I'm a Linux guy myself).
Hope life gets better.
FUDForum. Page generated in 0.01749 seconds
