Home » Eclipse Projects » NatTable » Howto render row as header.
Howto render row as header. [message #1015170] Wed, 27 February 2013 11:12
Alex Kipling is currently offline Alex Kipling
I am trying to render a row as a header.
I am doing it manually, since I do not have any SelectionLayer to create a RowHeaderLayer.
I came up with the following code, but the row is still not rendered as a header - the Data in DefaultRowHeaderLayerConfiguration are not used.
Do I miss something?
DataLayer headerLayer = new DataLayer(emptyOneCellHeaderDataProvider, 50, 20);
//just adding the 	Configuration does not work. Try overriding and using labels: add GridRegion.ROW_HEADER
ColumnLabelAccumulator overrideLabelAccumulator = new ColumnLabelAccumulator(){
	public void accumulateConfigLabels(LabelStack configLabels,
			int columnPosition, int rowPosition) {
		super.accumulateConfigLabels(configLabels, columnPosition, rowPosition);
		configLabels.addLabel(GridRegion.ROW_HEADER); //add GridRegion.ROW_HEADER, so that DefaultRowHeaderLayerConfiguration starts to work
headerLayer.setConfigLabelAccumulator(overrideLabelAccumulator);
//reuse the default configurations. This makes the row header look like a header.
DefaultRowHeaderLayerConfiguration configuration = new DefaultRowHeaderLayerConfiguration();
//add to layer
headerLayer.addConfiguration(configuration);
[Updated on: Wed, 27 February 2013 11:13]
Report message to a moderator
Previous Topic:KeyEvents not getting registered on WizardDialog
Next Topic:Release 1.0 date
Current Time: Fri May 24 23:19:07 EDT 2013
Powered by FUDForum. Page generated in 0.01459 seconds
