Hi!
I´ve been using eclipse for a couple of months and everything was working fine, but today when I started eclipse suddenly didn´t work and still not working, when I press the icon to start the program it automatically close.
I´ve installed again and now is doing the same but now says that eclipse has closed unexpectedly with a report.
Thank you.
Perhaps there was an update on your machine for the JRE that's installed
and that's causing a problem... You can control which JVM is used in
the eclipse.ini.
On 26/02/2013 8:02 PM, Julio Dominguez wrote:
> Hi!
> Thank you.
I am new to all of this and have a similar problem. I've been using Eclipse Juno 3.8 for a few days and it worked fine, but today, it refused to open. Instead, it freezes while "Loading org.eclipse.jdt.ui". Does anyone have any ideas what could be the issue?
