Home » Modeling » MDT (Model Development Tools) » convert BPMN20 OMG CMOF metamodel to ecore(convert BPMN20 OMG CMOF metamodel to ecore)
convert BPMN20 OMG CMOF metamodel to ecore [message #1011461] Tue, 19 February 2013 10:36 Go to next message
ila tak is currently offline ila tak
I'm trying to convert the BPMN20 OMG cmof metamodel to ecore, using the eclipse wizard. when i load the cmof metamodel i get errors (see attached image).
i have tried to get some inspiration from the tuto of Reiner Hille-Doering "Making of the BPMN 2.0 Meta Model for Eclipse: Merge and Conquer" but i didn't get the same result at the end.
  • Attachment: cmof.png
    (Size: 109.25KB, Downloaded 46 times)
Re: convert BPMN20 OMG CMOF metamodel to ecore [message #1011588 is a reply to message #1011461] Tue, 19 February 2013 16:22 Go to previous messageGo to next message
A first guess, given that you have provided very little information.
You are using Juno and consequently MDT/UML2 4.0 with UML 2.4.1 support.
You are using a BPMN that expects MDT/UML 3.x with UML 2.2 support.
Ed Willink
On 19/02/2013 20:32, ila tak wrote:
> Hello,
> Thanks
Re: convert BPMN20 OMG CMOF metamodel to ecore [message #1015099 is a reply to message #1011588] Wed, 27 February 2013 08:18 Go to previous message
Hi Ed,
Thanks a lot for your answer, i managed to fix the errors
[Updated on: Wed, 27 February 2013 08:20]
Report message to a moderator
Previous Topic:[BPMN2] extending attribute of Process node
Next Topic:Extending BPMN2 Metamodel
Current Time: Tue May 28 15:11:55 EDT 2013
Powered by FUDForum. Page generated in 0.01600 seconds
