Home » Eclipse Projects » Hudson » Hudson version compatible with Java 1.7(Hudson version compatible with Java 1.7)
Hudson version compatible with Java 1.7 [message #1006369] Thu, 31 January 2013 00:40 Go to next message
Manu Goyal is currently offline Manu Goyal
In my project, we are previously using the Hudson version 1.319 with Java 1.6. However, recently we have upgraded to Java 1.7 version and the hudson version we are using is not supported with Java 1.7
Could you please confirm the hudson version which we can use with Java 1.7
Re: Hudson version compatible with Java 1.7 [message #1006745 is a reply to message #1006369] Fri, 01 February 2013 11:32 Go to previous messageGo to next message
Steve Christou is currently offline Steve Christou
Hudson 3.0 should be compatible with java 7. (http://eclipse.org/downloads/download.php?file=/hudson/war/hudson-3.0.0.war)
 * @author Steven Christou
 * @dev    Hudson-ci
Re: Hudson version compatible with Java 1.7 [message #1015005 is a reply to message #1006745] Wed, 27 February 2013 02:54 Go to previous message
Tang Shi-Ming is currently offline Tang Shi-Ming
at least Hudson 3.0 is compatible with JDK 1.7. I'm using the two.
Previous Topic:currently logged in user should be as HUDSON_USER
Next Topic:Hudson + SVN + Eclipse
Current Time: Tue May 21 13:44:44 EDT 2013
Powered by FUDForum. Page generated in 0.01713 seconds
