| Problem with copying and pasting in XULRunner Browser on Eclipse [message #1014660] |
Tue, 26 February 2013 03:29  |
Stella Lok Messages: 10 Registered: September 2012 |
Junior Member |
I am having a problem with copying and pasting (via CTRL+C and CTRL+V) into XULRunner browser text fields in Eclipse. I am using 32-bit XULRunner 10.0.2 on 32-bit Eclipse Juno on 64-bit Windows 7.
To reproduce the problem, I have written a simple SWT dialog class called TestDialog, that contains an SWT.MOZILLA Browser. TestDialog has okPressed() overridden to instantiate and open another instance of TestDialog.
When I run TestDialog directly via a main() method in Java, the CTRL+C and CTRL+V copying and pasting works in all instances of TestDialog.
However, I have problems with copying and pasting when I open TestDialog in an AbstractHandler subclass in my Eclipse plugin. In the first instance of TestDialog, I am able to do CRTL+C and CTRL+V in the Browser. However, in the subsequent instances of TestDialog, CRTL+C and CTRL+V have no more effect.
I also see the following stack trace on Eclipse, whenever I do CTRL+C or CRTL+V, including for the first instance of TestDialog:
Stack trace for CTRL+C:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-26 16:17:19.192
!MESSAGE
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.core.commands.NotHandledException: There is no handler to execute for command org.eclipse.ui.edit.copy
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.executeCommand(KeyBindingDispatcher.java:276)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.press(KeyBindingDispatcher.java:494)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.processKeyEvent(KeyBindingDispatcher.java:545)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.filterKeySequenceBindings(KeyBindingDispatcher.java:366)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher.access$0(KeyBindingDispatcher.java:313)
at org.eclipse.e4.ui.bindings.keys.KeyBindingDispatcher$KeyDownFilter.handleEvent(KeyBindingDispatcher.java:82)
at org.eclipse.swt.widgets.Display.filterEvent(Display.java:1262)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1052)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1077)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1062)
at org.eclipse.swt.widgets.Widget.notifyListeners(Widget.java:774)
at org.eclipse.swt.browser.Mozilla.HandleEvent(Mozilla.java:4692)
at org.eclipse.swt.browser.Mozilla$19.method3(Mozilla.java:1200)
at org.eclipse.swt.internal.mozilla.XPCOMObject.callback3(XPCOMObject.java:266)
at org.eclipse.swt.internal.win32.OS.DispatchMessageW(Native Method)
at org.eclipse.swt.internal.win32.OS.DispatchMessage(OS.java:2546)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3756)
at org.eclipse.jface.window.Window.runEventLoop(Window.java:825)
at org.eclipse.jface.window.Window.open(Window.java:801)
at org.test.menu.MyTestHandler.execute(MyTestHandler.java:35)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:293)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:48)
at java.lang.reflect.Method.invoke(Method.java:600)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:851)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:744)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:728)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:667)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1022)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:916)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:585)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:540)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: org.eclipse.core.commands.NotHandledException: There is no handler to execute for command org.eclipse.ui.edit.copy
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:84)
... 66 more
Stack trace for CTRL+V:
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-26 16:17:31.758
!MESSAGE
!STACK 0
org.eclipse.e4.core.di.InjectionException: org.eclipse.core.commands.NotHandledException: There is no handler to execute for command org.eclipse.ui.edit.paste
Caused by: org.eclipse.core.commands.NotHandledException: There is no handler to execute for command org.eclipse.ui.edit.paste
... 66 more
If anyone can shed some light on this issue, it'd be much appreciated
[Updated on: Tue, 26 February 2013 03:31] Report message to a moderator
| Re: Problem with copying and pasting in XULRunner Browser on Eclipse [message #1015447 is a reply to message #1014660] |
Thu, 28 February 2013 10:46  |
Grant Gayed Messages: 2128 Registered: July 2009 |
Your question would be best asked in the eclipse.platform
newsgroup/forum, but I'll at least take a guess.
I've verified that copy/paste is working in a stand-alone
XULRunner-based Browser on Windows, so I suspect that in your case the
eclipse platform is filtering the pressed keys, sees the Ctrl+C/+V, and
attempts to invoke Copy/Paste functionality on the Browser rather than
letting the keys go through. However this attempt is failing, possibly
because the Browser does not implement copy()/paste() API, or possibly
for some other reason. Someone on the eclipse.platform newsgroup/forum
could probably tell you more definitely.
Grant
On 2/26/2013 3:29 AM, Stella Lok wrote:
> TestDialog.
> However, I have problems with copying and pastig when I open TestDialog
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> sun.reflect.DelegatingMethodAccessorImpl.invoke(DelegatingMethodAccessorImpl.java:25)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
> at
> at
> at
> at
> at
> org.eclipse.ui.PlatformUI.createAndRunWorkbench(PlatformUI.java:149)
> at
> org.eclipse.ui.internal.ide.application.IDEApplication.start(IDEApplication.java:124)
> at
> org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
> at
> org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
> at
> at
> at
> at
> at
> at
> at
> at
> ... 66 more
> !MESSAGE !STACK 0
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> ... 66 more
> If anyone can shed some light on this issue, it'd be much appreciated :)
FUDForum. Page generated in 0.11774 seconds
