| How to import a RegisteredLibrary using the method getRegisteredLibraries () [message #1014484] |
Mon, 25 February 2013 17:41  |
sabrina ing Messages: 39 Registered: February 2013 |
Member |
I am using Eclipse-SDK-4.3M5 Kepler and papyrus kepler.
I would like to use the Command/Handler to add a popup menu using commands and
Handlers in the view of the Model Explorer when creating a papyrus Model.
This popup menu has a menu that allows you to import a platform from a list, but the
problem is when I use the method getRegisteredLibraries () to Get
the registered library(platform), it doesnt'work and it doesn't import the platform
I used: RegisteredLibrary [] = platform RegisteredLibrary.getRegisteredLibraries ();
I'd appreciate any help on this. Thanks,
Best Regards,
FUDForum. Page generated in 0.01797 seconds
