| Dynamic menu with MHandledMenuItem [message #1013263] |
Sat, 23 February 2013 01:31  |
Kirill Zotkin Messages: 11 Registered: July 2009 |
Junior Member |
Hello!
I've looked at http://stackoverflow.com/questions/12315749/e4-dynamic-menu-contributions and decided to implement with Kepler the dynamic menu for creating children of EObjects. (The complete source is here.)
...class CreateChildContribution...
@Inject
public void setSelection(
@Optional @Named(IServiceConstants.ACTIVE_SELECTION) EObject eObject) {
this.eObject = eObject;
@AboutToShow
public void aboutToShow(List<MMenuElement> items) {
items.clear();
if (eObject == null)
return;
EditingDomain domain = editingDomainProvider.getEditingDomain();
Collection<?> newChildDescriptors = domain.getNewChildDescriptors(
eObject, null);
if (newChildDescriptors != null) {
for (Object descriptor : newChildDescriptors) {
Command emfCommand = CreateChildCommand.create(domain,
itemProvider, descriptor,
Collections.singletonList(eObject));
Object emfFeature = ((CommandParameter) descriptor)
.getFeature();
MHandledMenuItem menuItem = MMenuFactory.INSTANCE
.createHandledMenuItem();
menuItem.setLabel(emfCommand.getLabel());
MCommand modeledCommand = (MCommand) modelService.find(
"org.domainworkbench.command.createChild", app);
menuItem.setCommand(modeledCommand);
menuItem.setContributorURI("platform:/plugin/org.domainworkbench");
MParameter parameter = MCommandsFactory.INSTANCE
.createParameter();
parameter
.setName("org.domainworkbench.commandparameter.emfCommand");
parameter.setValue(String.valueOf(emfCommand.hashCode()));
menuItem.getParameters().add(parameter);
parameter = MCommandsFactory.INSTANCE.createParameter();
parameter
.setName("org.domainworkbench.commandparameter.emfFeature");
parameter.setValue(String.valueOf(emfFeature.hashCode()));
Map<String, Object> parameters = new HashMap<String, Object>();
parameters.put(
"org.domainworkbench.commandparameter.emfCommand",
emfCommand);
parameters.put(
"org.domainworkbench.commandparameter.emfFeature",
emfFeature);
ParameterizedCommand command = commandService.createCommand(
"org.domainworkbench.command.createChild", parameters);
menuItem.setWbCommand(command);
items.add(menuItem);
I also have a type-id, although it's convertToObject doesn't gets called:
public class ContextParameterValueConverter extends
AbstractParameterValueConverter {
protected IEclipseContext context;
public ContextParameterValueConverter() {
super();
this.context = createContext();
private IEclipseContext createContext() {
return context = EclipseContextFactory.create();
// Bundle bundle = FrameworkUtil
// .getBundle(ContextParameterValueConverter.class);
// BundleContext bundleContext = bundle.getBundleContext();
// IEclipseContext serviceContext = EclipseContextFactory
// .getServiceContext(bundleContext);
// return serviceContext.getActiveLeaf();
public Object convertToObject(String parameterValue)
throws ParameterValueConversionException {
return context.get(parameterValue);
public String convertToString(Object parameterValue)
String result = String.valueOf(parameterValue.hashCode());
context.set(result, parameterValue);
return result;
The menu is shown correctly but the handler's execute method doesn't get called because the type of the parameter value is String.
I wonder why this type-id doesn't applies to the binding parameter, and why it is not possible to pass the object value to MParameter.setValue()?
I am ready to contribute.
[Updated on: Sat, 23 February 2013 21:32] Report message to a moderator
| Re: Dynamic menu with MHandledMenuItem [message #1013292 is a reply to message #1013263] |
Sat, 23 February 2013 03:18   |
Junior Member |
@Inject
parameter
context.set("org.domainworkbench.commandparameter.emfCommand",
emfCommand);
// parameter.setValue(String.valueOf(emfCommand.hashCode()));
Didn't helped in this example too. Anyway, i understand that this was the wrong way.
UPD:
With String handler arg type it works (type-id is registered against a java.lang.Object).
[Updated on: Sat, 23 February 2013 05:22] Report message to a moderator
| Re: Dynamic menu with MHandledMenuItem [message #1013582 is a reply to message #1013292] |
Sat, 23 February 2013 21:21  |
Junior Member |
Ok, to summarize:
@AboutToShow
items.clear();
return;
eObject, null);
.getFeature();
parameters.put(
emfCommand);
parameters.put(
emfFeature);
Here's how it works for String parameter type:
@Execute
public void execute(
@Named("org.domainworkbench.commandparameter.emfCommand") String emfCommand,// Command
// emfCommand,
@Named("org.domainworkbench.commandparameter.emfFeature") Object feature
System.out.println(emfCommand + "\n\t" + feature.toString());
Without type-id you need to pass Strings in commandService.createCommand(...parameters).
Althoug i still suspect that there is another way with MParameters.
For objects:
String result = parameterValue.getClass().getName() + "@"
+ parameterValue.hashCode();
return result;
@Execute
@Named("org.domainworkbench.commandparameter.emfCommand") Command emfCommand,
@Named("org.domainworkbench.commandparameter.emfFeature") Object feature) {
emfCommand.execute();
System.out.println(emfCommand.getResult() + " " + feature);
Since it looks like MParameter's value is not used, i have added the call of convertToObject to the ParameterizedCommand.getParameterMap() in order to get it working. The bug is filed at https://bugs.eclipse.org/bugs/show_bug.cgi?id=401611
[Updated on: Sun, 24 February 2013 03:35] Report message to a moderator
FUDForum. Page generated in 0.01691 seconds
