Home » Eclipse Projects » Rich Client Platform (RCP) » Why I export the product , but the exe can not run?
Why I export the product , but the exe can not run? [message #1011791] Wed, 20 February 2013 04:10 Go to next message
xu yang is currently offline xu yang
I want to export my RCP project. The product can been launched and I can sucessfully export the RCP project. But when I run the exe program, it occurs the errors. I have seen the log file. It as follow:
!SESSION 2013-02-19 23:32:33.303 -----------------------------------------------
eclipse.buildId=unknown
java.version=1.6.0_35
BootLoader constants: OS=linux, ARCH=x86_64, WS=gtk, NL=en_US
Command-line arguments: -os linux -ws gtk -arch x86_64 -consoleLog
!ENTRY org.eclipse.osgi 2 0 2013-02-19 23:32:34.173
!MESSAGE One or more bundles are not resolved because the following root constraints are not resolved:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-19 23:32:34.174
!MESSAGE Bundle initial@reference:file:plugins/com.astrium.geo.sf.ui_1.0.0.201302192325.jar/ was not resolved.
!SUBENTRY 2 com.astrium.geo.sf.ui 2 0 2013-02-19 23:32:34.174
!MESSAGE Missing required bundle org.eclipse.nebula.widgets.gallery.source_0.5.3.
!ENTRY org.eclipse.osgi 2 0 2013-02-19 23:32:34.190
!MESSAGE The following is a complete list of bundles which are not resolved, see the prior log entry for the root cause if it exists:
!SUBENTRY 1 org.eclipse.osgi 2 0 2013-02-19 23:32:34.191
!MESSAGE Bundle com.astrium.geo.sf.ui_1.0.0.201302192325 was not resolved.
!SUBENTRY 2 com.astrium.geo.sf.ui 2 0 2013-02-19 23:32:34.191
!MESSAGE Bundle com.astrium.geo.sf.ui.streetFactory_1.0.0 [2] was not resolved.
!SUBENTRY 2 com.astrium.geo.sf.ui.streetFactory 2 0 2013-02-19 23:32:34.192
!MESSAGE Missing host com.astrium.geo.sf.ui_[1.0.0,1.1.0).
!ENTRY org.eclipse.osgi 4 0 2013-02-19 23:32:34.192
!MESSAGE Application error
!STACK 1
java.lang.RuntimeException: Application "com.astrium.geo.sf.ui" could not be found in the registry. The applications available are: org.eclipse.ant.core.antRunner, org.eclipse.equinox.app.error, org.eclipse.help.base.infocenterApplication, org.eclipse.help.base.helpApplication, org.eclipse.help.base.indexTool, org.eclipse.nebula.examples.application.
at org.eclipse.equinox.internal.app.EclipseAppContainer.startDefaultApp(EclipseAppContainer.java:248)
at org.eclipse.equinox.internal.app.MainApplicationLauncher.run(MainApplicationLauncher.java:29)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:369)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:620)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:575)
at org.eclipse.equinox.launcher.Main.run(Main.java:1408)
at org.eclipse.equinox.launcher.Main.main(Main.java:1384)
I don't kown why. The product can run. Why when I export the program, the error occurs?
Please give me some help. Thank you very much
Re: Why I export the product , but the exe can not run? [message #1013018 is a reply to message #1011791] Fri, 22 February 2013 11:07 Go to previous message
Rafael Fogel is currently offline Rafael Fogel
Are you trying to run an exe file on linux?
Previous Topic:Problems building a product
Next Topic:[PDE build] Headless feature where all bundles are already built fails
Current Time: Sat May 25 17:33:20 EDT 2013
Powered by FUDForum. Page generated in 0.01498 seconds
