Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc) » [Edapt] Migrate programmatically - Incorrect strategy?
| [Edapt] Migrate programmatically - Incorrect strategy? [message #1012887] |
Fri, 22 February 2013 06:39  |
Kirsten M. Z. Messages: 106 Registered: July 2010 |
Hi there and thanks for your efforts on Edapt so far.
Edapt is exactly what is needed in our project. However, we are not able to get everything working well right now. I have to mention that Edapt (UI) does not run on Juno/Kepler. Some error messages, missing buttons etc. Therefore, we cannot use Edapt as expected and it is hard to learn how Edapt works.
However, this is not the actual problematic spot. We need to migrate programmatically, so we started investigating the code anyway. Due to the lack of advanced documentation and examples, it was hard to get the first steps working. A very simple use case (renaming of an attribute) worked. A slightly more difficult case does not work (deletion of an attribute and creation of a new attribute). The console output:
Migrate...
Release 1
Step 1
Step 2
Step 3
Step 4
Step 5
Step 6
Step 7
...done
Exception in thread "main" java.lang.IllegalArgumentException: The feature 'name' is not a valid changeable feature
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eOpenSet(BasicEObjectImpl.java:1145)
at org.eclipse.emf.ecore.impl.BasicEObjectImpl.eSet(BasicEObjectImpl.java:1075)
at org.eclipse.emf.edapt.migration.BackwardConverter.initProperties(BackwardConverter.java:145)
at org.eclipse.emf.edapt.migration.BackwardConverter.initProperties(BackwardConverter.java:109)
at org.eclipse.emf.edapt.migration.BackwardConverter.convert(BackwardConverter.java:54)
at org.eclipse.emf.edapt.migration.Persistency.saveModel(Persistency.java:109)
at org.eclipse.emf.edapt.migration.execution.Migrator.migrateAndSave(Migrator.java:162)
at MinimalExample.main(MinimalExample.java:66)
Ok, I don't think that the problem is Edapt. I really think that the Problem is our code or the arrangement of our files. The solution is probably very easy. However, we have no idea how Edapt is expected to work. Before I post all the code of a minimal example and required files, here the arrangement:
AClassInstance.xmi ---- meta ----> MyLibraryOld.ecore
MyLibrary.ecore (copy of "MyLibraryOld.ecore") ---- refactor ----> MyLibrary.ecore + MyLibrary.hist (the Edapt history of changes)
AClassInstance.xmi ---- migration using the history ----> AClassInstance.xmi ***crash***
All the code and the files we got so far. I will also try attaching them.
public class MinimalExample {
* @param args
Resource.Factory.Registry.INSTANCE.getExtensionToFactoryMap().put("*",
new XMIResourceFactoryImpl());
ResourceSet resourceSet = new ResourceSetImpl();
resourceSet.getPackageRegistry().put(HistoryPackage.eNS_URI,
HistoryPackage.eINSTANCE);
Resource resource = resourceSet.getResource(
URI.createFileURI("T:\\AClassInstance.xmi"), true);
Resource resourceHistory = resourceSet.getResource(
URI.createFileURI("T:\\MyLibrary.hist"), true);
History history = (History) resourceHistory.getContents().get(0);
Migrator mig = new Migrator(history, new ClassLoaderFacade(Thread
.currentThread().getContextClassLoader()));
// mig.setLevel(ValidationLevel.HISTORY);
mig.setLevel(ValidationLevel.NONE);
List<URI> uris = new ArrayList<URI>();
uris.add(resource.getURI());
LibraryExtractor libex = new LibraryExtractor();
Library lib = libex.extractLibrary(BaseLibrary.class);
OperationRegistry.getInstance()
.registerLibrary(lib.getImplementation());
try {
mig.migrateAndSave(uris, history.getFirstRelease(), history
.getLastRelease(), new PrintStreamProgressMonitor(
System.out));
} catch (MigrationException e) {
e.printStackTrace();
AClassInstance.xmi
<?xml version="1.0" encoding="ASCII"?>
<ml:AClass xmi:version="2.0"
xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance"
xmlns:ml="http://www.example.org/MyLibrary"
xsi:schemaLocation="http://www.example.org/MyLibrary MyLibraryOld.ecore"
name="Simple Name"/>
MyLibraryOld.ecore
<ecore:EPackage xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" name="MyLibrary" nsURI="http://www.example.org/MyLibrary" nsPrefix="ml">
<eClassifiers xsi:type="ecore:EClass" name="AClass">
<eStructuralFeatures xsi:type="ecore:EAttribute" name="name" lowerBound="1">
<eType xsi:type="ecore:EDataType" href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</eStructuralFeatures>
</eClassifiers>
</ecore:EPackage>
MyLibrary.ecore
<eAnnotations source="http://www.eclipse.org/edapt">
<details key="historyURI" value="MyLibrary.hist"/>
</eAnnotations>
<eStructuralFeatures xsi:type="ecore:EAttribute" name="AnotherProp" lowerBound="1"
eType="ecore:EDataType http://www.eclipse.org/emf/2002/Ecore#//EInt" defaultValueLiteral="0"/>
</eClassifiers>
</ecore:EPackage>
MyLibrary.hist
<history:History xmi:version="2.0" xmlns:xmi="http://www.omg.org/XMI" xmlns:xsi="http://www.w3.org/2001/XMLSchema-instance" xmlns:ecore="http://www.eclipse.org/emf/2002/Ecore" xmlns:history="http://www.eclipse.org/emf/edapt/history/0.3">
<releases date="2013-02-22T12:04:33.758+0100" label="Initial">
<changes xsi:type="history:CompositeChange">
<changes xsi:type="history:Create">
<element href="MyLibrary.ecore#/"/>
<changes xsi:type="history:Set" featureName="name" dataValue="MyLibrary">
</changes>
<changes xsi:type="history:Set" featureName="nsURI" dataValue="http://www.example.org/MyLibrary">
</changes>
<changes xsi:type="history:Set" featureName="nsPrefix" dataValue="ml">
</changes>
</changes>
<changes xsi:type="history:Create" referenceName="eAnnotations">
<target href="MyLibrary.ecore#/"/>
<element href="MyLibrary.ecore#//%http:%2F%2Fwww.eclipse.org%2Fedapt%"/>
<changes xsi:type="history:Set" featureName="source" dataValue="http://www.eclipse.org/edapt">
</changes>
</changes>
<changes xsi:type="history:Create" referenceName="details">
<target href="MyLibrary.ecore#//%http:%2F%2Fwww.eclipse.org%2Fedapt%"/>
<element href="MyLibrary.ecore#//%http:%2F%2Fwww.eclipse.org%2Fedapt%/@details.0"/>
<changes xsi:type="history:Set" featureName="key" dataValue="historyURI">
</changes>
<changes xsi:type="history:Set" featureName="value" dataValue="MyLibrary.hist">
</changes>
</changes>
<changes xsi:type="history:Create" referenceName="eClassifiers">
<element href="MyLibrary.ecore#//AClass"/>
<changes xsi:type="history:Set" featureName="name" dataValue="AClass">
</changes>
</changes>
<changes xsi:type="history:Create" referenceName="eStructuralFeatures" element="//@releases.1/@changes.0/@element">
<target href="MyLibrary.ecore#//AClass"/>
<changes xsi:type="history:Set" element="//@releases.1/@changes.0/@element" featureName="name" dataValue="name"/>
<changes xsi:type="history:Set" element="//@releases.1/@changes.0/@element" featureName="lowerBound" dataValue="1" oldDataValue="0"/>
<changes xsi:type="history:Set" element="//@releases.1/@changes.0/@element" featureName="eType">
<referenceValue href="http://www.eclipse.org/emf/2002/Ecore#//EString"/>
</changes>
</changes>
</changes>
</releases>
<releases>
<changes xsi:type="history:Delete" referenceName="eStructuralFeatures">
<element xsi:type="ecore:EAttribute" name="name" lowerBound="1">
</element>
</changes>
<changes xsi:type="history:Create" referenceName="eStructuralFeatures">
<element href="MyLibrary.ecore#//AClass/AnotherProp"/>
</changes>
<changes xsi:type="history:Set" featureName="name" dataValue="AnotherProp">
</changes>
<changes xsi:type="history:Set" featureName="eType">
<referenceValue href="http://www.eclipse.org/emf/2002/Ecore#//EInt"/>
</changes>
<changes xsi:type="history:Set" featureName="defaultValueLiteral" dataValue="">
</changes>
<changes xsi:type="history:Set" featureName="defaultValueLiteral" dataValue="0" oldDataValue="">
</changes>
<changes xsi:type="history:Set" featureName="lowerBound" dataValue="1" oldDataValue="0">
</changes>
</releases>
</history:History>
[Updated on: Fri, 22 February 2013 06:39] Report message to a moderator
| Re: [Edapt] Migrate programmatically - Incorrect strategy? [message #1014694 is a reply to message #1012887] |
Tue, 26 February 2013 04:44   |
Maximilian Koegel Messages: 118 Registered: July 2009 |
Hi Kirsten,
thank you for reporting your issue with Edapt!
I am not sure if this causes the problem, but did you try to obtain the
migrator with the code from the tutorial:
http://www.eclipse.org/edapt/libraryexample.php#migrator
Maximilian
Am 22.02.2013 12:39, schrieb Kirsten M. Z.:
> Migrate...
> Release 1
> Step 1
> Step 2
> Step 3
> Step 4
> Step 5
> Step 6
> Step 7
> ..done
> * @param args
> public static void main(String[] args) {
> try {
> System.out));
> AClassInstance.xmi
> MyLibraryOld.ecore
> </eClassifiers>
> </ecore:EPackage>
> MyLibrary.ecore
> </eAnnotations>
> </eClassifiers>
> </ecore:EPackage>
> MyLibrary.hist
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </releases>
> <releases>
> </element>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </changes>
> </releases>
> </history:History>
Maximilian Kögel
Get Professional Eclipse Support: http://eclipsesource.com/munich
| Re: [Edapt] Migrate programmatically - Incorrect strategy? [message #1016191 is a reply to message #1015963] |
Tue, 05 March 2013 07:29   |
yes, that´s true, it is the easiest way to evolve, but in general you
can also provide the migrator with manual information of source and
target version for migration. This information could be stored somewhere
else.
Maximilian
Am 04.03.2013 13:33, schrieb Kirsten M. Z.:
> Oh, and there was another important issue in my strategy... sorry, that
> I forgot that in my previous post:
> - If the meta model evolves, also the namespace (NS URI) has to be
> changed, e.g. "http://xxx/v1" => "http://xxx/v2". I found this in an
> example, but there are not too much hints about that requirement!
Maximilian Kögel
Current Time: Thu May 23 18:01:42 EDT 2013
Powered by FUDForum. Page generated in 0.01961 seconds
