Home » Modeling » OCL » OCL for XCore
OCL for XCore [message #1012779] Fri, 22 February 2013 03:11 Go to next message
David Michonneau is currently offline David Michonneau
Member
I have an xcore model, and I would like to edit OCL constraints. What is the best way to do it? I see that OCL has its own XText editor for .ecore files, which seems to be a different grammar than the xcore one, but I don't find any menu entry to edit ocl rules for xcore. How can I add OCL rules to my xcore model (I do not have an .ecore).
David
[Updated on: Fri, 22 February 2013 03:12]
Report message to a moderator
Re: OCL for XCore [message #1012804 is a reply to message #1012779] Fri, 22 February 2013 03:54 Go to previous message
Using Xcore you can edit embedded EAnnotations, but that will be painful
and not get any syntax or semantic checking.
Using Xcore you must be able to export a *.ecore and edit it with
OCLinEcore, which was available two years before Xcore.
Buit really you should decide which camp you want to be in:
If you like tools related to OMG specifications you should use
OCLinEcore or OCL in UML (Papyrus).
If you like Java-like pragmatics you should use Xcore and Xbase.
Ed Willink
> David
Previous Topic:CompleteOCL standalone validation of uml model
Next Topic:OCL in XMI instances of Ecore
Current Time: Fri May 24 12:17:58 EDT 2013
Powered by FUDForum. Page generated in 0.01798 seconds
