| Re: Simulation in BPMN2.0 modeler [message #1012506 is a reply to message #1012494] |
Thu, 21 February 2013 12:24   |
Hi Hassan,
Currently the "Simulation" tab is only there for compatibility and to allow you to edit those properties for the jbpm5 runtime. Simulation of a process is not yet possible from the eclipse BPMN2 Modeler, but it IS available with the jBPM Web Designer so we wanted to provide support for this in the eclipse editor as early as possible.
Note that the jBPM Web Designer implements a subset of the newly emerging Business Process Simulation standard that is being defined by the bpswg. You may have a different concept of what "simulation" means, e.g. tracing a running business process which, IMHO, falls more into the BAM category.
Tracing and simulation are features that are in the project plan for the BPMN2 Modeler, unfortunately I haven't had much time to devote to this. If you DO decide to to look into coding this new functionality, please let me know and I'll be happy to answer any questions you might have
Cheers!
Bob
FUDForum. Page generated in 0.07376 seconds
