Home » Modeling » OCL » OCL in XMI instances of Ecore
| OCL in XMI instances of Ecore [message #1012459] |
Thu, 21 February 2013 10:48  |
John Guerson Messages: 36 Registered: August 2011 |
Member |
The metamodel of my domain independent language is specified in Ecore (*.ecore).
For instance, assuming that the name of my language is "ABCD", i have the metamodel: ABCD.ecore that defines my language ABCD.
Thus, a model of my ABCD language is for example (myFirstModel.xmi), possibly rename for myFirstModel.abcd,
wherein the xmi instance of that ecore model is, in fact, my ABCD model.
Now, if i want to add OCL constraints to my model myFirstModel.xmi/myFirstModel.abcd,
Is there a way to do this using OCL implementation of Eclipse?
Until now, i have figured out that OCL only specifies constraints in Ecore & UML models.
Thus i think that it is not possible to parse the constraints against that ABCD model (xmi instance of Ecore model).
Am i right?
I've been struggling with this issue a long time ago,
My solution for this problem today is just transform my ABCD model into UML model in order to
parse the constraints against the ABCD model. Doing that, i'm able to use the OCL/UML binding provided by EMF's implementation of OCL.
Att.
John
[Updated on: Thu, 21 February 2013 10:50] Report message to a moderator
| Re: OCL in XMI instances of Ecore [message #1012486 is a reply to message #1012459] |
Thu, 21 February 2013 11:43   |
Ed Willink Messages: 3151 Registered: July 2009 |
It is easy to get confused by meta-levels, which just might be your
problem, but probably not.
You suggest transforming to the OCL/UML binding. This is perhaps the
hardest approach since UML is so rich. Ecore would be easier.
I'm not clear whether you are familiar with the OCLinEcore editor, which
makes life much easier. It uses Xtext technology and a UML-aligned pivot
model, so that you could say it actually does an Ecore/UML to Pivot
transformation to use OCL.
You could replicate that with an ABCD to Pivot transformation.
I haven't checked whether this actually works, but in principle if you
have a model that extends the lightweight DomainPackage, DomainClass,
DomainProperty, DomainOperation etc interfaces you might be able to use
OCL more directly. Of course you'll be the first to try so expect
teething difficulties.
But returning to the meta-model levels, do you really need your own
language? you will have to replicate a lot of tools, whereas if you can
use Ecore as your language all the EMF projects are there for free.
Of course if you really want your own language, do you really want OCL?
If you can live with Java-like pragmatisms, Xtext, Xbase and their
friends provide a very powerful, better integrated, better supported
solution.
Ed Willink
On 21/02/2013 15:48, John Guerson wrote:
> (*.ecore). For instance, assuming that the name of my language is
> possibly rename for myFirstModel.abcd, wherein the xmi instance of
> Ecore & UML models. Thus i think that it is not possible to parse the
> Am i right?
> into UML model in order to parse the constraints beeing able to use
> Att.
> John
| Re: OCL in XMI instances of Ecore [message #1012654 is a reply to message #1012486] |
Thu, 21 February 2013 19:53   |
Member |
Hi Ed, thanks for the quickly reply, as always.
Yes, i first thought in transforming it into Ecore but i ended up transforming it into UML anyway.
The thing is that i need to somehow get those textual OCL constraints, related to that ABCD model (xmi instance of Ecore i.e. my model ) for transformation purposes i.e.
transforming those OCL constraints to another language via Java.
I'm not familiar with OCLinEcore. If i understood correctly, the solution pointed by you is to transform the ABCD model to the UML-aligned Pivot model, right?
I do not understand much of that Pivot implementation. Can you give me a reference?
I'm only familiar with the OCL implementations: org.eclipse.ocl.ecore/uml. I use the Complete OCL Editor to write the OCL constraints in the generated UML model equivalent to my ABCD model.
With respect to the language, yes, in fact, it is an implementation made by other colleagues and for now, it will remain like that i.e. designed in Ecore, even with the downsides, i am aware of that.
With respect to the use of OCL, i need to write rules to complement that ABCD model (mainly invariants and derivations).
Are you aware of another reference for other types of languages that play the same role of OCL w.r.t. invariant rules and derivations?
The ABCD language should be in fact an UML profile, an extension of UML, but it was implemented as another language, designed in Ecore, therefore, with that, i think we lost some important UML and OCL tool support.
I really appreciate your attention,
Many thanks
John
[Updated on: Thu, 21 February 2013 20:09] Report message to a moderator
| Re: OCL in XMI instances of Ecore [message #1012807 is a reply to message #1012654] |
Fri, 22 February 2013 03:57  |
I'm sorry, but my previous reply seems to answer your questions.
Look at the OCL project page fior links through to documentationm.
Ed Willink
> transformation purposes i.e. transforming those OCL constraints to
> a reference?
> Many thanks
> John
Current Time: Sat May 18 17:29:36 EDT 2013
Powered by FUDForum. Page generated in 0.02313 seconds
