| Re: org.eclipse.graphiti.ui.editor.DiagramEditorInput [message #1012919 is a reply to message #1012468] |
Fri, 22 February 2013 08:07  |
Michael Wenz Messages: 1267 Registered: July 2009 Location: Walldorf, Germany |
Alex,
there is a mixture of versions. Probably you use Graphiti 0.9.x (part of
Eclipse Juno), while you refer to the Graphiti 0.8.x (part of Indigo)
documentation. The link below points to the Indigo docu at least. The Juno
version is at http://help.eclipse.org/juno/index.jsp?nav=%2F22
The background is that there was an (incompatible) change in the editor API
also affecting DiagramEditorInput. It now stores only a URI of the diagram,
which means that you will need an editing domain to actually resolve teh
diagram instance.
Michael
FUDForum. Page generated in 0.01867 seconds
