Home » Eclipse Projects » Rich Client Platform (RCP) » Export and Running RCP Prduct with Native DLLs(Export Succesfull - Run Configuration Fails)
icon9.gif  Export and Running RCP Prduct with Native DLLs [message #1012383] Thu, 21 February 2013 08:08
Phil M. Fischer is currently offline Phil M. Fischer
Member
Hi all,
I am currently working on including some native DLLs to my eclipse RCP. These dlls are quite unique and i want to ship them with my exported product build (maven tycho product build).
I found a good example in the internet that explains how to handle the DLLs in combination with a RCP feature. Following this example they get perfectly installed into my RCP Application's root directory and they are well exxecuted. So thanks for that Smile
but now using the run configuration from within eclipse, it looks like the dlls do not get deployed. My code fails on loading the dlls and tells me that the dlls could not be found in in java.library.path Sad
Does anyone have a good clue on how to get both the export and the run configuration perfectly working?
Cheers
Phil
Previous Topic:Hide perspective using xml ?
Next Topic:Refresh TreeViewer after open file action
Current Time: Mon May 20 02:08:43 EDT 2013
Powered by FUDForum. Page generated in 0.02075 seconds
