| Re: Attaching one column to the right border? [message #1012756 is a reply to message #1012341] |
Fri, 22 February 2013 02:30  |
Dirk Fauth Messages: 522 Registered: July 2012 |
Quote:If I manage it to implement the freezing on the right side - i will contribute!
Some thoughts and possible hints on this:
1. The CompositeFreezeLayer is composed to have the non frozen region at the right bottom coordinate. To change the behaviour the way you like, this needs to be changed. A really nice contribution would be to make this configurable somehow. Also taking into account where the frozen columns and frozen rows should be composed.
2. The FreezeCommandHandler transforms the commands into IFreezeCoordinatesProvider, which are responsible to calculate the top left and the bottom right position for the FreezeLayer to use. They need to take the composition configuration into account.
Hope that helps,
Dirk
FUDForum. Page generated in 0.02048 seconds
