Home » Eclipse Projects » WindowBuilder » WindowBuilder Can not render GUI(WindowBuilder Designer does not show GUI if I call two or more than two level methods)
icon4.gif  WindowBuilder Can not render GUI [message #1011863] Wed, 20 February 2013 06:46 Go to next message
Sikandar Ali is currently offline Sikandar Ali
package com.swimap.omc.dcctool.view;
import java.awt.EventQueue;
public class MyFrame extends JFrame {
private static final long serialVersionUID = 1L;
private JPanel contentPane;
* Launch the application.
EventQueue.invokeLater(new Runnable() {
public void run() {
try {
MyFrame frame = new MyFrame();
frame.setVisible(true);
} catch (Exception e) {
e.printStackTrace();
* Create the frame.
public MyFrame() {
setDefaultCloseOperation(JFrame.EXIT_ON_CLOSE);
setBounds(100, 100, 450, 300);
contentPane = new JPanel();
contentPane.setBorder(new EmptyBorder(5, 5, 5, 5));
contentPane.setLayout(new GridBagLayout());
contentPane.add(getExpPathTf());
setContentPane(contentPane);
private JTextField getExpPathTf() {
JTextField exportPathTf = SwingUtil.createJTextField();
exportPathTf.setText("sikandar");
exportPathTf.setEditable(false);
return exportPathTf;
private static class SwingUtil {
public static JTextField createJTextField() {
JTextField tf = new JTextField();
tf.setBounds(10, 10, 100, 20);
return tf;
  • Attachment: MyFrame.java
    (Size: 1.39KB, Downloaded 30 times)
Re: WindowBuilder Can not render GUI [message #1012154 is a reply to message #1011863] Wed, 20 February 2013 20:23 Go to previous messageGo to next message
Eric Clayberg is currently offline Eric Clayberg
See the WindowBuilder docs on how to create and use Factory classes.
You will need to make the SwingUtil class a public top-level class (private/inner classes are not allowed) and mark the factory methods accordingly for WB to use them. Once I did that, your example rendered just fine.
icon4.gif  Re: WindowBuilder Can not render GUI [message #1012249 is a reply to message #1012154] Thu, 21 February 2013 02:36 Go to previous messageGo to next message
Thank you Eric Clayberg,
I feel that its not only a problem of Inner Private Class, please use these two files.
MyFrame1.java Razz
MyFrame2.java (Can't render UI) Sad
In the attached files there is a only one line difference
"System.out.println("abc");",
Please correct me If I amd doing something wrong. Sad
Re: WindowBuilder Can not render GUI [message #1012961 is a reply to message #1012249] Fri, 22 February 2013 09:22 Go to previous message
Your initial example was caused by using an inner/private class.
Your new example is something entirely different and also working as designed (for different reasons).
As written, your getTF() method does not represent a supported component creation pattern.
The method name begins with "get" which implies a getter, but it actually creates a new component every time rather than following the typical lazy creation pattern.
Even when it appears to "work", this is just a side effect of a different feature.
public JTextField getTF() {
  return SwingUtil.createTF();
We have support for evaluating simple "single return statement" methods at design time to provide values for constants, parameters, etc. Once you add a second statement, we will no longer evaluate it given the likelihood of dangerous side effects at design time.
So...if you want to make it a real getter, follow the normal lazy creation patter like this:
private JTextField tf;
private JTextField getTF() {
  if (tf == null) {
    tf = SwingUtil.createTF();
  return tf;
And yes, extract SwingUtil into a top-level class, rename it to SomethingFactory, or mark the createTF() method as a factory...
class SwingUtil {
   * @wbp.factory
  public static JTextField createTF() {
    tf.setBounds(20, 20, 200, 20);
    tf.setText("Test : Text");
    return tf;
Previous Topic:Java IDE and WindowBuilder
Next Topic:JTable data display
Current Time: Sat May 25 19:25:43 EDT 2013
Powered by FUDForum. Page generated in 0.01675 seconds
