| "Many-Model to Model" transformation with qvto? [message #1011932] |
Wed, 20 February 2013 09:33  |
Miriam Hundemer Messages: 6 Registered: February 2013 |
Junior Member |
Hi all,
I am still new to qvto but my newest project already provides my with kind of a special issue which I could not find an answer for up to now:
In my project I want to transform several input models (xml files), that are all based on the same meta-model, to one single output model (uml).
Is there a way to do such a "many-model to model" transformation in qvto or is only one input model possible at a time?
If this does not work, another approach could be to use a programm/script to do the model-to-model transformations seperately and then join them afterwards.
Regarding this second approach my question is: Is it possible to execute qvto commands in java code?
Thanks a lot,
Miriam
| Re: "Many-Model to Model" transformation with qvto? [message #1013001 is a reply to message #1012978] |
Fri, 22 February 2013 10:40   |
Junior Member |
Ok,
now I've found the chapter you ment Ed, but as I use the specification Fabio mentioned above, it is indeed on page 94, sorry for the confusion.
But if I'm interpreting this right, the "@" is not exactly what I need. As I understand , the "@" is only used for the parameters of a mapping in order to specify the precise in or out model they "belong to". But the in and out models still have to be defined in the transformation declaration above and are fixed afterwards.
transformation T(in src:S, out dest1:D, out dest2:D);
mapping X::foo(inout Y@dest1) : Y@dest2;
// 'X' is a class of 'S' metamodel and 'Y' is a class of 'D' metamodel
Here, the inmodels src and the outmodels dest1 and dest2 are defined in the transformation declaration and used later as parameter type in the mapping operation.
Perhaps I didn't explain my problem properly:
What I would need in my project (I think) is kind of beeing able to have a list (of variable length) of in models in the transformation declaration because from one execution of the transformation to the next, it is possible that the number of in models (xml files) changes.
Is there something like the second example?
//transformation with more than one but fixed number of inmodels
transformation T1 (in inModel1:Metamodel, inModel2:Metamodel, out outModel:UML);
//transformation with variable number of inmodels
transformation T (<list_of_inModels>, out outModel:UML);
All of the inmodels will be of the same metamodel.
| Re: &amp;quot;Many-Model to Model&amp;quot; transformation with qvto? [message #1013029 is a reply to message #1013001] |
Fri, 22 February 2013 11:17  |
Ed Willink Messages: 3185 Registered: July 2009 |
If it's a variable number of models, I suggest creating a super-model
that references all the others.
Ed Willink
On 22/02/2013 15:40, Miriam Hundemer wrote:
> Ok,
> outModel:UML);
FUDForum. Page generated in 0.01761 seconds
