| [Texo] ArrayIndexOutOfBoundsException [message #1011916] |
Wed, 20 February 2013 08:58  |
Bastian Wagenfeld Messages: 88 Registered: January 2013 |
Member |
Hi Martin,
during our tests with the DataGenerator we had to drop our database schema several times. When the schema is empty and we execute jsonTexoResource.query("select u from User u", new HashMap<String, Object>(), 0, Integer.MAX_VALUE); the server returns an error.
The exception that is thrown on the server side looks like this:
java.lang.ArrayIndexOutOfBoundsException: -1
at java.util.Vector.elementData(Vector.java:730)
at java.util.Vector.remove(Vector.java:828)
at org.eclipse.emf.texo.server.service.RetrieveModelOperation.internalExecute(RetrieveModelOperation.java:97)
at org.eclipse.emf.texo.server.service.UpdateInsertModelOperation.internalExecute(UpdateInsertModelOperation.java:69)
at org.eclipse.emf.texo.server.service.ModelOperation.execute(ModelOperation.java:59)
at org.eclipse.emf.texo.server.web.WebServiceHandler.doPost(WebServiceHandler.java:111)
at org.eclipse.emf.texo.server.web.WebServiceHandler.doPut(WebServiceHandler.java:125)
at org.eclipse.emf.texo.server.web.WebServiceServlet.doPut(WebServiceServlet.java:73)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:650)
at javax.servlet.http.HttpServlet.service(HttpServlet.java:728)
at org.apache.catalina.core.ApplicationFilterChain.internalDoFilter(ApplicationFilterChain.java:305)
at org.apache.catalina.core.ApplicationFilterChain.doFilter(ApplicationFilterChain.java:210)
at org.apache.catalina.core.StandardWrapperValve.invoke(StandardWrapperValve.java:222)
at org.apache.catalina.core.StandardContextValve.invoke(StandardContextValve.java:123)
at org.apache.catalina.authenticator.AuthenticatorBase.invoke(AuthenticatorBase.java:581)
at org.apache.catalina.core.StandardHostValve.invoke(StandardHostValve.java:171)
at org.apache.catalina.valves.ErrorReportValve.invoke(ErrorReportValve.java:99)
at org.apache.catalina.valves.AccessLogValve.invoke(AccessLogValve.java:936)
at org.apache.catalina.core.StandardEngineValve.invoke(StandardEngineValve.java:118)
at org.apache.catalina.connector.CoyoteAdapter.service(CoyoteAdapter.java:407)
at org.apache.coyote.http11.AbstractHttp11Processor.process(AbstractHttp11Processor.java:1004)
at org.apache.coyote.AbstractProtocol$AbstractConnectionHandler.process(AbstractProtocol.java:589)
at org.apache.tomcat.util.net.JIoEndpoint$SocketProcessor.run(JIoEndpoint.java:310)
at java.util.concurrent.ThreadPoolExecutor.runWorker(ThreadPoolExecutor.java:1110)
at java.util.concurrent.ThreadPoolExecutor$Worker.run(ThreadPoolExecutor.java:603)
at java.lang.Thread.run(Thread.java:722)
If I execute http://localhost:8080/praesto/jsonws/User just as a GET call, it returns
"endRow": "-1",
"_eclass": "response|ResponseType",
"totalRows": "0",
"status": "success",
"startRow": "0",
"data": [(0)],
"_title": "success"
} so I assume the right behaviour of the query call above should return an empty resource, but shouldn't throw an error, right?
Best regards
Bastian
| Re: [Texo] ArrayIndexOutOfBoundsException [message #1011919 is a reply to message #1011916] |
Wed, 20 February 2013 09:05   |
Martin Taal Messages: 5054 Registered: July 2009 |
Seems to be a clear bug, will solve that in parallel with the other one you entered.
gr. Martin
On 02/20/2013 02:58 PM, Bastian Wagenfeld wrote:
> Hi Martin,
> "endRow": "-1",
> "totalRows": "0",
> "startRow": "0",
> "data": [(0)],
> "_title": "success"
> right?
> Best regards
> Bastian
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
FUDForum. Page generated in 0.01709 seconds
