| Is the mobile widget set compatible with the standard set of Dojo widgets? [message #1010553] |
Sun, 17 February 2013 12:29  |
Richard Moulton Messages: 79 Registered: August 2011 Location: Devon, UK |
Member |
I created a new Mobile Web client application project (using EDT 0.8.2). I then created a simple RUI handler using some of the mobile widgets. I then wanted to include some of the standard Dojo widgets within the project so added the org.eclipse.edt.rui.dojo.remote_0.8.2 project to the EGL build path.
I can successfully view the mobile RUI handler within the design and preview tabs from the IDE. However, when I deploy the application to Tomcat 6 and point my browser at the deployed web page the page is blank, nothing is shown.
If I remove org.eclipse.edt.rui.dojo.remote_0.8.2 project from the EGL build path and then redeploy I can see the web page.
Is the set of base Dojo widgets compatible with the mobile widgets? Should this work?
My plan was to have one project containing a standard web application RUI handler and equivalent mobile application RUI handler.
Richard
FUDForum. Page generated in 0.01453 seconds
