Best practice for "invisible" figures with an EditPart? [message #1010887] |
Mon, 18 February 2013 07:20  |
I'm wondering whether there is such a thing as a best practice for handling cases where you must have an EditPart (e.g., to implement a needed Adapter) without wanting a Figure to actually be displayed.
In my case, I have a graph model where elements can be annotated with "meta" - non-semantic - information, e.g., at which coordinates a node should be placed. I.e., nodes don't "have" constraints which I can set/get via set/getConstraints() or a similar method. (I believe this to be a best practice in itself, as visual information shouldn't be mixed up with domain information? I'm using a mixed case.)
I need EditParts for this kind of annotation, because I need to notify their parent to refresh() whenever annotations' values are changed in a Command (e.g., node.getAnnotation("X_COORD").setValue(100)). The annotations' EditPart thus has an Adapter which calls getParent().refresh() in notifyChanged().
However, I obviously don't need a Figure for the annotations' EditPart, as this info shouldn't be displayed.
At the moment, I have the EditPart's createFigure() simply return new Figure().
Is there a better way to do this? I felt better if I wasn't creating such an awful amount of Figure objects .
Thanks!
| Re: Best practice for "invisible" figures with an EditPart? [message #1011556 is a reply to message #1010887] |
Tue, 19 February 2013 14:40   |
To specify further, the EditPart in question extends AbstractGraphicalEditPart, which AFAIK needs a non-null return from its createFigure() method. I've tried to have my EditPart extend AbstractEditPart instead, but I get a ClassCastException error (cf. error stack below), possibly because the EditPart extending AbstractEditPart is a child of an extension of AbstractGraphicalEditPart(?)...
Any suggestions are *much* appreciated . Thanks!
java.lang.ClassCastException: my.editor.editparts.AnnotationEditPart cannot be cast to org.eclipse.gef.GraphicalEditPart
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addChildVisual(AbstractGraphicalEditPart.java:208)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:211)
at org.eclipse.gef.editparts.AbstractEditPart.refreshChildren(AbstractEditPart.java:781)
at org.eclipse.gef.editparts.AbstractEditPart.refresh(AbstractEditPart.java:726)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.refresh(AbstractGraphicalEditPart.java:644)
at org.eclipse.gef.editparts.AbstractEditPart.addNotify(AbstractEditPart.java:253)
at org.eclipse.gef.editparts.AbstractGraphicalEditPart.addNotify(AbstractGraphicalEditPart.java:223)
at org.eclipse.gef.editparts.AbstractEditPart.addChild(AbstractEditPart.java:212)
at org.eclipse.gef.editparts.SimpleRootEditPart.setContents(SimpleRootEditPart.java:105)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:617)
at org.eclipse.gef.ui.parts.AbstractEditPartViewer.setContents(AbstractEditPartViewer.java:626)
at my.editor.Editor.initializeGraphicalViewer(Editor.java:55)
at org.eclipse.gef.ui.parts.GraphicalEditor.createGraphicalViewer(GraphicalEditor.java:158)
at org.eclipse.gef.ui.parts.GraphicalEditor.createPartControl(GraphicalEditor.java:171)
at org.eclipse.gef.ui.parts.GraphicalEditorWithFlyoutPalette.createPartControl(GraphicalEditorWithFlyoutPalette.java:75)
at org.eclipse.ui.internal.EditorReference.createPartHelper(EditorReference.java:670)
at org.eclipse.ui.internal.EditorReference.createPart(EditorReference.java:465)
at org.eclipse.ui.internal.WorkbenchPartReference.getPart(WorkbenchPartReference.java:595)
at org.eclipse.ui.internal.PartPane.setVisible(PartPane.java:313)
at org.eclipse.ui.internal.presentations.PresentablePart.setVisible(PresentablePart.java:180)
at org.eclipse.ui.internal.presentations.util.PresentablePartFolder.select(PresentablePartFolder.java:270)
at org.eclipse.ui.internal.presentations.util.LeftToRightTabOrder.select(LeftToRightTabOrder.java:65)
at org.eclipse.ui.internal.presentations.util.TabbedStackPresentation.selectPart(TabbedStackPresentation.java:473)
at org.eclipse.ui.internal.PartStack.refreshPresentationSelection(PartStack.java:1245)
at org.eclipse.ui.internal.PartStack.setSelection(PartStack.java:1198)
at org.eclipse.ui.internal.PartStack.showPart(PartStack.java:1597)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:493)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:103)
at org.eclipse.ui.internal.PartStack.add(PartStack.java:479)
at org.eclipse.ui.internal.EditorStack.add(EditorStack.java:112)
at org.eclipse.ui.internal.EditorSashContainer.addEditor(EditorSashContainer.java:63)
at org.eclipse.ui.internal.EditorAreaHelper.addToLayout(EditorAreaHelper.java:225)
at org.eclipse.ui.internal.EditorAreaHelper.addEditor(EditorAreaHelper.java:213)
at org.eclipse.ui.internal.EditorManager.createEditorTab(EditorManager.java:808)
at org.eclipse.ui.internal.EditorManager.openEditorFromDescriptor(EditorManager.java:707)
at org.eclipse.ui.internal.EditorManager.openEditor(EditorManager.java:666)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditorBatched(WorkbenchPage.java:2942)
at org.eclipse.ui.internal.WorkbenchPage.busyOpenEditor(WorkbenchPage.java:2850)
at org.eclipse.ui.internal.WorkbenchPage.access$11(WorkbenchPage.java:2842)
at org.eclipse.ui.internal.WorkbenchPage$10.run(WorkbenchPage.java:2793)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2789)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2773)
at org.eclipse.ui.internal.WorkbenchPage.openEditor(WorkbenchPage.java:2764)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:651)
at org.eclipse.ui.ide.IDE.openEditor(IDE.java:610)
at org.eclipse.ui.actions.OpenFileAction.openFile(OpenFileAction.java:99)
at org.eclipse.ui.actions.OpenSystemEditorAction.run(OpenSystemEditorAction.java:99)
at org.eclipse.ui.actions.RetargetAction.run(RetargetAction.java:221)
at org.eclipse.ui.navigator.CommonNavigatorManager$3.open(CommonNavigatorManager.java:185)
at org.eclipse.ui.OpenAndLinkWithEditorHelper$InternalListener.open(OpenAndLinkWithEditorHelper.java:48)
at org.eclipse.jface.viewers.StructuredViewer$2.run(StructuredViewer.java:866)
at org.eclipse.ui.internal.JFaceUtil$1.run(JFaceUtil.java:49)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
at org.eclipse.jface.viewers.StructuredViewer.fireOpen(StructuredViewer.java:864)
at org.eclipse.jface.viewers.StructuredViewer.handleOpen(StructuredViewer.java:1152)
at org.eclipse.ui.navigator.CommonViewer.handleOpen(CommonViewer.java:462)
at org.eclipse.jface.viewers.StructuredViewer$6.handleOpen(StructuredViewer.java:1256)
at org.eclipse.jface.util.OpenStrategy.fireOpenEvent(OpenStrategy.java:275)
at org.eclipse.jface.util.OpenStrategy.access$2(OpenStrategy.java:269)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:309)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4165)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3754)
at org.eclipse.ui.internal.Workbench.runEventLoop(Workbench.java:2701)
at org.eclipse.ui.internal.Workbench.runUI(Workbench.java:2665)
at org.eclipse.ui.internal.Workbench.access$4(Workbench.java:2499)
at org.eclipse.ui.internal.Workbench$7.run(Workbench.java:679)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:668)
at my.application.start(Saltomic.java:104)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:344)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:179)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:39)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:622)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:577)
at org.eclipse.equinox.launcher.Main.run(Main.java:1410)
at org.eclipse.equinox.launcher.Main.main(Main.java:1386)
| Re: Best practice for "invisible" figures with an EditPart? [message #1011945 is a reply to message #1011797] |
Wed, 20 February 2013 10:07   |
Hi Jan, and thanks for your answer.
My problem is that no visual information may be stored in the underlying EMF model, but I have (?) to set Constraints on the parent EditPart, don't I? So my workaround is to persist this information in the annotation.
However, if you let me know how to listen to the change of constraints, I'll be more than happy to listen .
| Re: Best practice for "invisible" figures with an EditPart? [message #1012372 is a reply to message #1011945] |
Thu, 21 February 2013 07:39  |
Jan Krakora Messages: 402 Registered: December 2009 Location: Prague |
Well, I've never used EMF before and I always have the visual representation tied to the domain model.
What about creating a visual representation model using the EMF as well? It would contain the constraints and a reference to the domain model. Some kind of wrapper.
This model would be model for EditParts.
FUDForum. Page generated in 0.01734 seconds
