Home » Modeling » TMF (Xtext) » ImportUri and scoping(ImportUri and scoping)
ImportUri and scoping [message #1008374] Tue, 12 February 2013 03:29 Go to next message
Girish Kumar is currently offline Girish Kumar
Hi All,
I got some problems with using importuri.
As per the documentation , i understand the scoping.
Anyway let me explain my problem.
1. MyDsl looks somewhat like this.
SI:
include+=Include*
types+=Type*
enums+=Enum*
consts+=Constant*
Include : 'include' importuri=STRING;
Type : 'type' name=ID '{'
Enum : 'enum' name=ID '{'
Constant: 'const' name=ID type=[TypeOrEnum] defaultValue=STRING;
TypeOrEnum : Type | Enum;
2. Now I have
test1.dsl
type type1 {
type type2 {
enum enum1 {
test2.dsl
include "test1.dsl"
const PI type1 "3.14"
The above line is not resolved as type1 is not visible.
3. After reading some posts, I came to know about ImportUriScoping.
So i changed the workflow as shown
before:
// scoping and exporting API
// fragment = scoping.ImportURIScopingFragment {}
// fragment = exporting.SimpleNamesFragment {}
fragment = scoping.ImportNamespacesScopingFragment {}
fragment = exporting.QualifiedNamesFragment {}
fragment = builder.BuilderIntegrationFragment {}
Now:
I changed to
//fragment = scoping.ImportNamespacesScopingFragment {}
//fragment = exporting.QualifiedNamesFragment {}
//fragment = builder.BuilderIntegrationFragment {}
After doing the above change , now i am able to see type1 in the content assist.
But the problem is i am able to see all the types/ enums which are present in the files
i.e test3.dsl can also access type1 but it is not being imported at all.
why this behaviour.
In this case it is so weird, i also get some errors telling type1 is not resolved, not in red indicator, instead in grey color
So what should i do inorder to get only the types of imported files available??
Thanks in advance
Re: ImportUri and scoping [message #1008515 is a reply to message #1008374] Tue, 12 February 2013 14:34 Go to previous messageGo to next message
Hao Xie is currently offline Hao Xie
Member
You may want to try with
Re: ImportUri and scoping [message #1009009 is a reply to message #1008515] Thu, 14 February 2013 04:42 Go to previous messageGo to next message
No it doesn't works..
Re: ImportUri and scoping [message #1010762 is a reply to message #1008374] Mon, 18 February 2013 02:43 Go to previous message
Jan Kohnlein is currently offline Jan Kohnlein
1) 'importURI' is case sensitive. Naming a the property 'importuri' will
not have any effect.
2) What does test3 import?
Am 12.02.13 09:29, schrieb Girish Kumar:
> Hi All,
> SI:
> include+=Include*
> types+=Type*
> enums+=Enum*
> consts+=Constant*
> 2. Now I have test1.dsl
> type type1 {
> type type2 {
> enum enum1 {
> test2.dsl
> include "test1.dsl"
> before:
> // scoping and exporting API fragment =
> Now:
> I changed to // scoping and exporting API
> // scoping and exporting API //fragment =
> assist.
> why this behaviour.
> available??
> Thanks in advance
Need professional support for Eclipse Modeling?
Go visit: http://xtext.itemis.com
Previous Topic:Node model reconciler and editing domain
Next Topic:XMI resource to xText resource
Current Time: Thu May 23 22:06:29 EDT 2013
Powered by FUDForum. Page generated in 0.01793 seconds
