Home » Eclipse Projects » Virgo » Deployment in Eclipse results in empty MANIFEST.MF
Deployment in Eclipse results in empty MANIFEST.MF [message #1009021] Thu, 14 February 2013 05:00 Go to next message
Andi Buechler
since uprading to Virgo Tooling 1.0.1.201302081934-SNAPSHOT I get empty manifests when deploying within Eclipse. The manifest files are correctly generated in the Eclipse project, but the ones copied to the stage directory just contain a header:
Manifest-Version: 1.0
Built-By: john doe
Build-Jdk: 1.6.0_39
Created-By: Maven Integration for Eclipse
Is this releated to Bug 379233?
Andi
Re: Deployment in Eclipse results in empty MANIFEST.MF [message #1009902 is a reply to message #1009021] Fri, 15 February 2013 19:23 Go to previous message
Leo Dos Santos is currently offline Leo Dos Santos
Do you have a sample that reproduces the issue? Also, what tool is generating your Manifests? The "Created-By: Maven Integration for Eclipse" suggests to me that you're using some sort of Maven Bundlor integration instead of the Virgo IDE Bundlor integration maybe?
Previous Topic:Static EclipseLink weaving causing endless bundle refresh
Next Topic:Virgo Survey (2013) Results
Current Time: Sat May 25 17:26:49 EDT 2013
Powered by FUDForum. Page generated in 0.01523 seconds
