Home » Modeling » GMF (Graphical Modeling Framework) » Properties View
Properties View [message #1009471] Fri, 15 February 2013 02:44 Go to next message
Daniel König is currently offline Daniel König
Hello!
Is there a common practice to change the look of the properties view? (like in the second picture)
This tutorial is outdated and I wonder if there is any other workflow / best practice to achieve it?
Currently I only have the table layout within tabs.
http://www.eclipse.org/articles/Article-Tabbed-Properties/images/properties_before.jpg
http://www.eclipse.org/articles/Article-Tabbed-Properties/images/properties_after.jpg
Re: Properties View [message #1009703 is a reply to message #1009471] Fri, 15 February 2013 09:53 Go to previous messageGo to next message
Ralph Gerbig is currently offline Ralph Gerbig
you can use the extension points provided by eclipse to get another properties view tab with whatever you like. All you need to do is to define an own propertyTab and propertySection. GMF generates a bit of source code which you can find in your generated xxx.diagram.sheet package. A tutorial on property sheets can be found here http://www.eclipse.org/articles/Article-Tabbed-Properties/tabbed_properties_view.html
Ralph
Re: Properties View [message #1009711 is a reply to message #1009703] Fri, 15 February 2013 10:09 Go to previous messageGo to next message
Thank you. I will look into that.
I just wondered if there is anything which I can use to generate these views Wink
Daniel
Re: Properties View [message #1010788 is a reply to message #1009711] Mon, 18 February 2013 03:47 Go to previous message
you could take a look at EEF to get such things generated for EMF models and use them in you GMF editor.
Ralph
Previous Topic:impl cannot be resolved or is not a field
Next Topic:How to install GMF runtime?
Current Time: Wed May 22 13:48:52 EDT 2013
Powered by FUDForum. Page generated in 0.05626 seconds
