Home » Eclipse Projects » Hudson » "Invoke Maven 3" build step missing
| "Invoke Maven 3" build step missing [message #1007789] |
Thu, 07 February 2013 08:55  |
Joost Joost Messages: 5 Registered: February 2013 |
Junior Member |
When creating a free style job, I have no "Invoke Maven 3" build step.
I do have "Invoke Ant", "Execute shell", "Invoke Maven 2 (legacy)", "Execute Windows batch command", "Inject environment variables".
If I go to the manage plugins section, I do have the "Hudson :: Maven 3 :: Plugin" plugin installed and enabled.
Any idea what is wrong? I'm using Hudson 2.2.0.
| Re: "Invoke Maven 3" build step missing [message #1007828 is a reply to message #1007823] |
Thu, 07 February 2013 11:34   |
Junior Member |
I'm not seeing anything about the plugin not being able to load in the log output:
<Feb 7, 2013 2:46:02 PM CET> <Notice> <WebLogicServer> <BEA-000330> <Started WebLogic Managed Server "Hudson_Server_1" for domain "hudson_domain" running in Production Mode>
Feb 7, 2013 2:46:02 PM hudson.model.Hudson$5 onAttained
INFO: Prepared all plugins
INFO: Started all plugins
INFO: Augmented all extensions
<Feb 7, 2013 2:46:04 PM CET> <Notice> <WebLogicServer> <BEA-000365> <Server state changed to RUNNING>
<Feb 7, 2013 2:46:04 PM CET> <Notice> <WebLogicServer> <BEA-000360> <Server started in RUNNING mode>
Feb 7, 2013 2:46:06 PM hudson.model.Hudson$5 onAttained
INFO: Loaded all jobs
INFO: Completed initialization
Feb 7, 2013 2:46:07 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.web.context.support.StaticWebApplicationContext@1c344bac: display name [Root WebApplicationContext]; startup date [Thu Feb 07 14:46:07 CET 2013]; root of context hierarchy
Feb 7, 2013 2:46:07 PM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.web.context.support.StaticWebApplicationContext@1c344bac]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1c3fe9f8
Feb 7, 2013 2:46:07 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1c3fe9f8: defining beans [initialDirContextFactory,bindAuthenticator,ldapUserSearch,authenticationManager,authoritiesPopulator]; root of factory hierarchy
Feb 7, 2013 2:46:07 PM org.acegisecurity.ldap.DefaultInitialDirContextFactory setProviderUrl
INFO: URL 'ldap://oid.corp.com/dc=corp,dc=com', root DN is 'dc=corp,dc=com'
Feb 7, 2013 2:46:08 PM org.springframework.context.support.AbstractApplicationContext prepareRefresh
INFO: Refreshing org.springframework.web.context.support.StaticWebApplicationContext@1cc55aa7: display name [Root WebApplicationContext]; startup date [Thu Feb 07 14:46:08 CET 2013]; root of context hierarchy
Feb 7, 2013 2:46:08 PM org.springframework.context.support.AbstractApplicationContext obtainFreshBeanFactory
INFO: Bean factory for application context [org.springframework.web.context.support.StaticWebApplicationContext@1cc55aa7]: org.springframework.beans.factory.support.DefaultListableBeanFactory@1cc55b4a
Feb 7, 2013 2:46:08 PM org.springframework.beans.factory.support.DefaultListableBeanFactory preInstantiateSingletons
INFO: Pre-instantiating singletons in org.springframework.beans.factory.support.DefaultListableBeanFactory@1cc55b4a: defining beans [filter,legacy]; root of factory hierarchy
Feb 7, 2013 2:46:08 PM hudson.TcpSlaveAgentListener <init>
INFO: JNLP slave agent listener started on TCP port 43787
[EnvInject] - Injecting as environment variables the properties file path '/home/users/hudson/env.txt'
[EnvInject] - Variables injected successfully.
Feb 7, 2013 2:46:27 PM hudson.triggers.SafeTimerTask run
SEVERE: Timer task hudson.WebAppMain$2$1@1dfd375c failed
java.util.NoSuchElementException
at java.util.AbstractList$Itr.next(AbstractList.java:350)
at hudson.maven.MavenModuleSetBuild$1.notInSubsidiary(MavenModuleSetBuild.java:209)
at hudson.maven.MavenModuleSetBuild$1.<init>(MavenModuleSetBuild.java:202)
at hudson.maven.MavenModuleSetBuild.getChangeSetFor(MavenModuleSetBuild.java:190)
at hudson.maven.FilteredChangeLogSet.<init>(FilteredChangeLogSet.java:51)
at hudson.maven.MavenBuild.getChangeSet(MavenBuild.java:172)
at hudson.model.AbstractBuild.hasParticipant(AbstractBuild.java:321)
at hudson.model.User.getBuilds(User.java:368)
at hudson.WebAppMain$2$1.doRun(WebAppMain.java:258)
at hudson.triggers.SafeTimerTask.run(SafeTimerTask.java:54)
at java.util.TimerThread.mainLoop(Timer.java:512)
at java.util.TimerThread.run(Timer.java:462)
[Updated on: Thu, 07 February 2013 11:36] Report message to a moderator
| Re: "Invoke Maven 3" build step missing [message #1007855 is a reply to message #1007836] |
Thu, 07 February 2013 13:15   |
Winston Prakash Messages: 142 Registered: August 2011 Location: Fremont, CA USA |
That is really odd. because it does not list any of the plugins being loaded. The information about the plugins being loaded should be listed like the following
Started Jetty Server
Console reloading is ENABLED. Hit ENTER on the console to restart the context.
Feb 7, 2013 8:04:47 AM hudson.PluginManager createPluginStrategy
INFO: Plugin strategy: org.hudsonci.inject.internal.plugin.DelegatingPluginStrategy
Feb 7, 2013 8:04:47 AM hudson.model.Hudson$5 onAttained
INFO: Attained Loading bundled plugins
INFO: Started initialization
INFO: Attained null
INFO: Attained Listing up plugins
INFO: Attained Preparing plugins
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/copyartifact.hpl
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/promoted-builds.hpl
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/birt-charts.hpi
Feb 7, 2013 8:04:47 AM hudson.PluginManager$1$3$1 isDuplicate
INFO: Ignoring /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/copyartifact.hpl because /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/copyartifact.hpl is already loaded
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/git.hpi
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/jna-native-support-plugin.hpi
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/maven-plugin.hpi
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/maven3-plugin.hpi
INFO: Ignoring /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/promoted-builds.hpl because /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/promoted-builds.hpl is already loaded
Feb 7, 2013 8:04:48 AM hudson.model.Hudson$5 onAttained
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/rest-plugin.hpi
INFO: Listed all plugins
INFO: Attained Inspecting plugin /Users/wjprakash/Hudson/Hudson3-plugins/copyartifact-plugin/work/plugins/xpath-provider.hpi
INFO: Attained null
Feb 7, 2013 8:04:48 AM hudson.PluginManager$2$1$1 run
INFO: Loading plugin - copyartifact
INFO: Attained Loading plugins
Feb 7, 2013 8:04:51 AM hudson.model.Hudson$5 onAttained
INFO: Attained Loading plugin copyartifact
Feb 7, 2013 8:04:51 AM hudson.PluginManager$2$1$1 run
INFO: Loading plugin - promoted-builds
INFO: Attained Loading plugin promoted-builds
INFO: Loading plugin - birt-charts
INFO: Attained Loading plugin birt-charts
INFO: Loading plugin - git
Feb 7, 2013 8:04:52 AM hudson.model.Hudson$5 onAttained
INFO: Attained Loading plugin git
Feb 7, 2013 8:04:52 AM hudson.PluginManager$2$1$1 run
INFO: Loading plugin - jna-native-support-plugin
INFO: Attained Loading plugin jna-native-support-plugin
INFO: Loading plugin - maven-plugin
INFO: Attained Loading plugin maven-plugin
INFO: Loading plugin - maven3-plugin
Feb 7, 2013 8:04:53 AM hudson.model.Hudson$5 onAttained
INFO: Attained Loading plugin maven3-plugin
Feb 7, 2013 8:04:53 AM hudson.PluginManager$2$1$1 run
INFO: Loading plugin - rest-plugin
Feb 7, 2013 8:04:54 AM hudson.model.Hudson$5 onAttained
INFO: Attained Loading plugin rest-plugin
Feb 7, 2013 8:04:54 AM hudson.PluginManager$2$1$1 run
INFO: Loading plugin - xpath-provider
INFO: Attained Loading plugin xpath-provider
INFO: Attained null
INFO: Attained Checking cyclic dependencies
Feb 7, 2013 8:04:55 AM hudson.model.Hudson$5 onAttained
INFO: Attained Initializing plugin copyartifact
INFO: Attained Initializing plugin promoted-builds
INFO: Attained Initializing plugin birt-charts
INFO: Attained Initializing plugin git
INFO: Attained Initializing plugin jna-native-support-plugin
INFO: Attained Initializing plugin maven-plugin
INFO: Attained Initializing plugin maven3-plugin
INFO: Attained Initializing plugin rest-plugin
INFO: Attained Initializing plugin xpath-provider
Winston Prakash
Eclipse Hudson team
Current Time: Sun May 19 19:10:15 EDT 2013
Powered by FUDForum. Page generated in 0.04752 seconds
