Home » Modeling » EMF "Technology" (Ecore Tools, EMFatic, etc)  » [Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest()
[Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest() [message #1008990] Thu, 14 February 2013 04:05 Go to next message
peter meyer is currently offline peter meyer
Hello Martin,
we are evaluating Texo for a RCP Client/Tomcat server project.
In the Tomcat Server we run one webapp for CRUD data operations with Texo jsonws, in the same Tomcat we run Birt for serverside report generation. Both webapps need authorisation. We want to use the single sign on mechanismen which tomcat provide. This mechnismen use session/cookie information and share it between webapps in the same host.
To use this cool feature we must must be able to get and store session information from the HTTP Request in the RCP Client and put it in the following requests.
The communication of our RCP Client starts with a JSONEObjectStore.doHTTPRequest.
Would it be possible to provide in the JSONEObjectStore a method
afterConnect(HttpURLConnection con)
with the established HttpURLConnection as parameter, which is called in the doHTTPRequest method after the connection is established?
We could override this method (like beforeConnect) and get information from the connection.
best regards
Peter
[Updated on: Thu, 14 February 2013 04:06]
Report message to a moderator
Re: [Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest() [message #1009006 is a reply to message #1008990] Thu, 14 February 2013 04:35 Go to previous messageGo to next message
Martin Taal is currently offline Martin Taal
Hi Peter/Bernd,
Yes that's no problem, will add this.
Can you provide me with a diff or exact line number where to call afterConnect? (this to prevent one change-build cycle
if I accidentally choose the wrong location).
gr. Martin
On 02/14/2013 10:05 AM, peter meyer wrote:
> Hello Martin,
> is established?
With Regards, Martin Taal
Springsite/Elver.org
The Netherlands
Cell: +31 (0)6 288 48 943
Tel: +31 (0)84 420 2397
Fax: +31 (0)84 225 9307
Mail: mtaal@xxxxxxxx - mtaal@xxxxxxxx
Re: [Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest() [message #1009180 is a reply to message #1009006] Thu, 14 February 2013 10:55 Go to previous messageGo to next message
Hello Martin,
please place the afterConnect(conn) method between line 89 and line 90:
89 final OutputStream os = conn.getOutputStream();
89,5 afterConnect(conn);
90 os.write(bytes);
thank you and best regards
Peter/Bernd Wink
Re: [Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest() [message #1009565 is a reply to message #1009180] Fri, 15 February 2013 05:23 Go to previous messageGo to next message
Hello Martin,
thank you for your support. I hope that you have not yet implement the afterConnect. method.
This morning i recognized that the line number for the afterConnect method is not correct.
I will do some tests and give you feedback when i know the correct line number.
best regards
Peter
Re: [Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest() [message #1011100 is a reply to message #1009565] Mon, 18 February 2013 16:10 Go to previous messageGo to next message
Hi Peter,
I could not stop myself and added an afterRead method, let me know if that is sufficient (or not ofcourse):
http://git.eclipse.org/c/texo/org.eclipse.emf.texo.git/commit/?id=2a47c29fa295f3f6941b5a169019545ffdbb9a32
gr. Martin
On 02/15/2013 11:23 AM, peter meyer wrote:
> Hello Martin,
> best regards
> Peter
The Netherlands
Re: [Texo] provide a method to get cookie/session data from JsonObjectStore.doHTTPRequest() [message #1011300 is a reply to message #1011100] Tue, 19 February 2013 04:13 Go to previous message
Hi Martin,
my tests are running well with the new method.
thanks a lot for your support!
kind regards
Peter
Previous Topic:Texo: Auditing feature
Next Topic:[Texo] ArrayIndexOutOfBoundsException
Current Time: Sun May 19 12:03:46 EDT 2013
Powered by FUDForum. Page generated in 0.02807 seconds
