Home » Modeling » EMF » [CDO] Support to Postgresql 9.0
| [CDO] Support to Postgresql 9.0 [message #1009531] |
Fri, 15 February 2013 04:29  |
Marc Gil Messages: 70 Registered: July 2009 |
Member |
I'm trying to install CDO plugins and I realized that the plugin "org.eclipse.net4j.db.postgresql" is never loaded by Eclipse. I tried with the 4.0.SR2, 4.0.SR3, 4.1.SR1 CDO versions, and doesn't work.
I realized that this plugin needs a packages named "org.postgresql" and "org.postgresql.ds" between 8.3.0 (inclusive) and 9.0.0 (exclusive) version.
I needed to create a plugin with the 8.3 or 8.4 versions of postgres and compile it.
Any help to use postgresql 9.0 plugin version?
Marc
| Re: [CDO] Support to Postgresql 9.0 [message #1009558 is a reply to message #1009531] |
Fri, 15 February 2013 05:05   |
Christophe Bouhier Messages: 684 Registered: July 2009 |
Hi Marc,
I have some experience with running postgress.
I created a plugin containing the postgress JDBC driver.
Make sure the plugin version matches the net4j.progress version
requirement and export the packages. (I notice now the export has
version for some packages, I can't recall why this is, the driver is a
higher version).
Manifest-Version: 1.0
Bundle-ManifestVersion: 2
Bundle-Name: Postgresql
Bundle-SymbolicName: org.postgresql
Bundle-Version: 9.0.0.801
Bundle-ClassPath: postgresql-9.0-801.jdbc4.jar
Bundle-Vendor: postgresql.org
Export-Package: org.postgresql;version="8.9.9",
org.postgresql.copy,
org.postgresql.core,
org.postgresql.core.types,
org.postgresql.core.v2,
org.postgresql.core.v3,
org.postgresql.ds;version="8.9.9",
org.postgresql.ds.common,
org.postgresql.ds.jdbc23,
org.postgresql.ds.jdbc4,
org.postgresql.fastpath,
org.postgresql.geometric,
org.postgresql.gss,
org.postgresql.jdbc2,
org.postgresql.jdbc2.optional,
org.postgresql.jdbc3,
org.postgresql.jdbc3g,
org.postgresql.jdbc4,
org.postgresql.largeobject,
org.postgresql.ssl,
org.postgresql.translation,
org.postgresql.util,
org.postgresql.xa
Bundle-RequiredExecutionEnvironment: J2SE-1.5
Cheers Christophe
On 15-02-13 10:29, Marc Gil wrote:
> version.
> compile it.
> Marc
| Re: [CDO] Support to Postgresql 9.0 [message #1009573 is a reply to message #1009558] |
Fri, 15 February 2013 05:32   |
Eike Stepper Messages: 5153 Registered: July 2009 |
Am 15.02.2013 11:05, schrieb Christophe Bouhier:
> Hi Marc,
> Make sure the plugin version matches the net4j.progress version requirement and export the packages. (I notice now the
> export has version for some packages, I can't recall why this is, the driver is a higher version).
I think it's a NO GO to pretend lower package versions than they actually are!
The problem really must be addressed in /org.eclipse.net4j.db.postgresql/META-INF/MANIFEST.MF, which it is in CDO 4.2.
Cheers
/Eike
http://www.esc-net.de
> org.postgresql.gss,
> org.postgresql.ssl,
> org.postgresql.xa
> Cheers Christophe
>> version.
>> compile it.
>> Thanks,
>> Marc
| Re: [CDO] Support to Postgresql 9.0 [message #1009597 is a reply to message #1009571] |
Fri, 15 February 2013 06:10   |
Member |
Eike,
I don't know if I can use CDO 4.2, cause I'm developing under Eclipse 3.7.2... Could you confirm me if I can use it, please?
Anyway, as I told before, I just made a couple of jar to be able to use postgresql 8.3 and 8.4. And then I try to create a CDO server and all worked fine. But not always are working... First time I executed the CDO server (with the DB created) it works and fills the DB with some info. Then I stop the server, and if I try to start it again, I get the following exception:
org.postgresql.util.PSQLException: ERROR: current transaction is aborted, commands ignored until end of transaction block
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.ObjectTypeTable.getMaxID(ObjectTypeTable.java:185)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.DelegatingObjectTypeMapper.getMaxID(DelegatingObjectTypeMapper.java:85)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.AbstractHorizontalMappingStrategy.repairAfterCrash(AbstractHorizontalMappingStrategy.java:88)
at org.eclipse.emf.cdo.server.internal.db.mapping.horizontal.HorizontalMappingStrategy.repairAfterCrash(HorizontalMappingStrategy.java:204)
at org.eclipse.emf.cdo.server.internal.db.DBStore.repairAfterCrash(DBStore.java:654)
at org.eclipse.emf.cdo.server.internal.db.DBStore.reStart(DBStore.java:638)
at org.eclipse.emf.cdo.server.internal.db.DBStore.doActivate(DBStore.java:548)
Any idea about what's happening??
Marc
| Re: [CDO] Support to Postgresql 9.0 [message #1009602 is a reply to message #1009597] |
Fri, 15 February 2013 06:16   |
On 15-02-13 12:10, Marc Gil wrote:
> Eike,
> at
Yep, seen this one.
https://bugs.eclipse.org/bugs/show_bug.cgi?id=365602
> at
> at
> at
> at
> at
> Marc
| Re: [CDO] Support to Postgresql 9.0 [message #1009603 is a reply to message #1009597] |
Am 15.02.2013 12:10, schrieb Marc Gil:
> Eike,
> please?
It *should* work. But we don't test it!
> at
> at
> at
There were a couple similar problems with Postgres in particular, e.g.,
https://bugs.eclipse.org/bugs/show_bug.cgi?id=364809 , which have all been fixed in CDO 4.2.
Cheers
/Eike
| Re: [CDO] Support to Postgresql 9.0 [message #1009654 is a reply to message #1009637] |
Fri, 15 February 2013 08:06   |
Member |
Eike,
It's impossible to install CDO 4.2 on Eclipse 3.7.2. I'm trying it for a couple of hours, and there are a dependency to EMF Compare minimum version 2.0.0, and it could not be installed under Eclipse 3.7.2 So my problem come back to the start, where using postgresql and closing unproperty the server, throws this exception... I think no solution exists for CDO 4.0 for that problem. Maybe, the best (or the only) solution is to change the database and use, for instance, MySQL, isn't it?
Marc
[Updated on: Fri, 15 February 2013 08:07] Report message to a moderator
| Re: [CDO] Support to Postgresql 9.0 [message #1009678 is a reply to message #1009654] |
Fri, 15 February 2013 09:04   |
Am 15.02.2013 14:06, schrieb Marc Gil:
> Eike,
> to EMF Compare minimum version 2.0.0, and it could not be installed under Eclipse 3.7.2 :(
Oh, I forgot about that one! The bundles that depend on EMF Compare are optional. Please submit a bugzilla, so that I
can see how to factor these dependencies out of org.eclipse.emf.cdo.ui.team and move the Compare stuff into a separate,
optional feature.
CDO 4.0 is out of maintenance.
> for that problem.
No, not even in 4.1.
> Maybe, the best solution is to change the database and use, for instance, MySQL, isn't it?
Hard to judge for me whether that's an option for you ;-)
Cheers
/Eike
| Re: [CDO] Support to Postgresql 9.0 [message #1009839 is a reply to message #1009739] |
Fri, 15 February 2013 15:37   |
Member |
Hi David,
yes I'm using Eclipse 3.7.2 Modeling Package, and yes, EMF Compare 1.x is installes, and yes, when try to install 2.x it fails and Eclipse says that as 1.x is part of the bundle, 2.x cannot be installed...
The "problem" es that we developed our software from the modeling package, and we only added some features not included in this package. Trying to install the main environment from a plain Eclipse SDK, should be the last option for us at this moment. I hope that Eike could separate the plugins that depends on EMF Compare and build again CDO 4.2. If not, we will take other ways to try to use it
Thanks!
Marc
Current Time: Tue May 21 12:43:31 EDT 2013
Powered by FUDForum. Page generated in 0.02151 seconds
