| Remote Services with EMF generated objects and TENEO [message #1009082] |
Thu, 14 February 2013 06:54  |
Martin Maier Messages: 1 Registered: February 2013 |
Junior Member |
I have a project where I want to use the Riena remote services for transferring model objects from the server to the client.
On server side I have a model generated with EMF and persisted with TENEO and Hibernate.
When calling a method on the server, I get the following exception:
com.caucho.hessian.client.HessianRuntimeException: com.caucho.hessian.io.HessianFieldException: org.eclipse.emf.ecore.impl.EObjectImpl.eAdapters: java.util.ArrayList ([org.eclipse.emf.teneo.type.PersistentStoreAdapter@56431753]) cannot be assigned to 'org.eclipse.emf.common.util.BasicEList'
at com.caucho.hessian.client.HessianProxy.invoke(HessianProxy.java:232)
at $Proxy25.getUsers(Unknown Source)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:616)
at org.eclipse.riena.communication.core.hooks.AbstractHooksProxy.invoke(AbstractHooksProxy.java:69)
at org.eclipse.riena.communication.core.hooks.AbstractHooksProxy.invoke(AbstractHooksProxy.java:38)
at org.eclipse.riena.internal.communication.core.factory.CallHooksProxy.invoke(CallHooksProxy.java:66)
at $Proxy26.getUsers(Unknown Source)
Has anybody encountered the same problem and knows how to solve this?
Thanks!
Martin
FUDForum. Page generated in 0.01529 seconds
