| Bind ComboObjectEditor to property extension [message #1008651] |
Wed, 13 February 2013 07:35  |
Rui Domingues Messages: 162 Registered: October 2010 |
Hi.
In createBindings I was trying to create ComboObjectEditor for a property extension defined like this, where I indicated the possible values.
<property name="permissao" value="NIVEL0" type="EString"/>
I believe this is not possible, so I must define this property in my own ecore and bind it to the correct estructuralfeature. Is that right, innit?
[Updated on: Wed, 13 February 2013 07:35] Report message to a moderator
| Re: Bind ComboObjectEditor to property extension [message #1009156 is a reply to message #1008651] |
Thu, 14 February 2013 10:07  |
Ok. I figured it out.
For my purpose, I defined in ecore the elements with attributes I wanted. These must be annoted with, name and namespace ##targetNamespace (which I forgot).
Then with the necessary adjustments I could bind it as it is done in jbpm5 extension for Simulation.
FUDForum. Page generated in 0.01725 seconds
