| eAdapter is null [message #1008115] |
Sat, 09 February 2013 04:32  |
Dmitriy Shishkin Messages: 14 Registered: May 2012 |
Junior Member |
I use Common Navigator Framework for represent my model, but sometime (don't understand a reason) one of eAdapters becomes to null. And when I try to add some child to this element I have an exeption.
Can anybody explain me the reason and how to avoid it?
Dmitriy.
!ENTRY org.eclipse.ui 4 0 2013-02-09 13:21:22.612
!MESSAGE Unhandled event loop exception
!STACK 0
org.eclipse.e4.core.di.InjectionException: java.lang.NullPointerException
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:63)
at org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
at org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
at org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
at org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.executeItem(HandledContributionItem.java:814)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.handleWidgetSelection(HandledContributionItem.java:707)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.access$7(HandledContributionItem.java:691)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem$4.handleEvent(HandledContributionItem.java:630)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
Caused by: java.lang.NullPointerException
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.emf.ecore.util.EcoreEList.dispatchNotification(EcoreEList.java:249)
at org.eclipse.emf.common.notify.impl.NotifyingListImpl.remove(NotifyingListImpl.java:713)
at org.eclipse.emf.common.util.ECollections.setEList(ECollections.java:232)
at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.process(FeatureChangeImpl.java:593)
at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.apply(FeatureChangeImpl.java:518)
at org.eclipse.emf.ecore.change.impl.FeatureChangeImpl.apply(FeatureChangeImpl.java:493)
at org.eclipse.emf.ecore.change.impl.ChangeDescriptionImpl.apply(ChangeDescriptionImpl.java:298)
at org.eclipse.emf.transaction.util.CompositeChangeDescription.apply(CompositeChangeDescription.java:104)
at org.eclipse.emf.transaction.impl.TransactionImpl.doRollback(TransactionImpl.java:570)
at org.eclipse.emf.transaction.impl.TransactionImpl.commit(TransactionImpl.java:404)
at org.eclipse.emf.transaction.impl.TransactionalCommandStackImpl.doExecute(TransactionalCommandStackImpl.java:70)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:165)
at org.eclipse.emf.transaction.impl.AbstractTransactionalCommandStack.execute(AbstractTransactionalCommandStack.java:219)
at com.tes.als.component.ui.navigator.handler.RotatorHandler.execute(RotatorHandler.java:34)
at org.eclipse.ui.internal.handlers.HandlerProxy.execute(HandlerProxy.java:290)
at org.eclipse.ui.internal.handlers.E4HandlerProxy.execute(E4HandlerProxy.java:76)
at org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
... 34 more
Attachment: ccccccc.png
(Size: 30.73KB, Downloaded 85 times)
[Updated on: Sat, 09 February 2013 04:32] Report message to a moderator
| Re: eAdapter is null [message #1008985 is a reply to message #1008974] |
Thu, 14 February 2013 03:50  |
Ed Merks Messages: 24529 Registered: July 2009 |
Dmitriy,
If the code adding the adapters needs to be fixed where ever it may be.
It might well be the case that your code is doing things in some thread
that's causing adapters to be added in your thread. I know nothing
about the specifics of the common navigator framework, so I can't help
track down such a problem...
On 14/02/2013 9:27 AM, Dmitriy Shishkin wrote:
> Ed, thanks for reply.
> But how I can fix it? I haven't my own adapters, all adapters added
> from another plugins.. Is only solution is fix their sources?
> Thanks, and
> sorry for my english)
FUDForum. Page generated in 0.08301 seconds
