Home » Modeling » Compare » EMF Compare Installation
EMF Compare Installation [message #1008693] Wed, 13 February 2013 10:24 Go to next message
serhat gezgin is currently online serhat gezgin
whe i try to install EMF Compare on Install new Software option with
http://download.eclipse.org/modeling/emf/compare/updates/milestones/2.1
i have ;
Unable to connect to repository https://archive.eclipse.org/modeling/emf/compare/updates/milestones/2.1/content.xml
Connection timed out: connect or
Could not find http://archive.eclipse.org/modeling/emf/compare/updates/milestones/2.1/
problem and cant get compare.
Re: EMF Compare Installation [message #1008969 is a reply to message #1008693] Thu, 14 February 2013 03:21 Go to previous message
Laurent Goubet is currently offline Laurent Goubet
Please make sure that you follow the proper installation procedure :
- Help > Install New Software...
- Copy/paste the update site URL ( http://download.eclipse.org/modeling/emf/compare/updates/milestones/2.1 ), making sure that there is no "archive" in this url.
- hit "enter".
If this still fails, make sure you have no update site "registered" with this URL :
- Window > Preferences
- Go to "Install / Available Software sites"
- Copy paste the URL above in the filter list
If anything shows up, select it and hit "remove". Then, retry the installation procedure. If it still does not work, You'll probably have to download a new Eclipse, as this update site is functionnal (I just installed EMF Compare 2.1M5 from it in one of my Eclipses).
Laurent Goubet
Obeo
Previous Topic:bundle version set to 3.0.0 in archived p2 update site
Next Topic:EMF Compare 1.3 with Developer Guide
Current Time: Tue May 28 10:26:53 EDT 2013
Powered by FUDForum. Page generated in 0.01516 seconds
