Home » Eclipse Projects » BIRT » Reports are failing while closing DataFileReader(Reports are failing while closing DataFileReader)
Reports are failing while closing DataFileReader [message #1008904] Thu, 14 February 2013 00:13 Go to next message
Pavan Manala is currently offline Pavan Manala
Reports are failing in our production environment while closing DataFileReader. Below is the stack trace.
SEVERE [org.eclipse.birt.report.engine.api.impl.RunTask.doRun] : An error happened while running the report. Cause:java.lang.NullPointerException
at org.eclipse.birt.data.engine.executor.cache.disk.DataFileReader.close(DataFileReader.java:119)
at org.eclipse.birt.data.engine.executor.cache.disk.RowFile.closeReader(RowFile.java:284)
at org.eclipse.birt.data.engine.executor.cache.disk.RowFile.close(RowFile.java:270)
at org.eclipse.birt.data.engine.api.CloseListenerManager.closeAll(CloseListenerManager.java:38)
at org.eclipse.birt.data.engine.impl.DataEngineImpl.shutdown(DataEngineImpl.java:584)
at org.eclipse.birt.report.data.adapter.impl.DataRequestSessionImpl.shutdown(DataRequestSessionImpl.java:509)
at org.eclipse.birt.report.engine.data.dte.AbstractDataEngine.shutdown(AbstractDataEngine.java:348)
at org.eclipse.birt.report.engine.data.dte.DataGenerationEngine.shutdown(DataGenerationEngine.java:151)
at org.eclipse.birt.report.engine.executor.ExecutionContext.closeDataEngine(ExecutionContext.java:900)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:263)
at org.eclipse.birt.report.engine.api.impl.RunTask.run(RunTask.java:85)
at com.wellsfargo.reporting.manager.ReportGenerator.sendRequestToEngine(ReportGenerator.java:549)
at com.wellsfargo.reporting.manager.ReportGenerator.runReport(ReportGenerator.java:266)
at com.wellsfargo.reporting.jms.ReportingMDP.onMessage(ReportingMDP.java:45)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:543)
at org.springframework.jms.listener.AbstractMessageListenerContainer.invokeListener(AbstractMessageListenerContainer.java:482)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doExecuteListener(AbstractMessageListenerContainer.java:451)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.doReceiveAndExecute(AbstractPollingMessageListenerContainer.java:323)
at org.springframework.jms.listener.AbstractPollingMessageListenerContainer.receiveAndExecute(AbstractPollingMessageListenerContainer.java:261)
SEVERE [com.wellsfargo.reporting.manager.ReportGenerator.sendRequestToEngine] : Error generating the report :/ccer/design/offline/Decline_Transactions.rptdesign
org.eclipse.birt.report.engine.api.EngineException: Error happened while running the report.
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:269)
at com.wellsfargo.reporting.jms.ReportingMDP.onMessage(ReportingMDP.java:46)
at org.springframework.jms.listener.AbstractMessageListenerContainer.doInvokeListener(AbstractMessageListenerContainer.java:544)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.invokeListener(DefaultMessageListenerContainer.java:982)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.executeOngoingLoop(DefaultMessageListenerContainer.java:974)
at org.springframework.jms.listener.DefaultMessageListenerContainer$AsyncMessageListenerInvoker.run(DefaultMessageListenerContainer.java:876)
at java.lang.Thread.run(Thread.java:637)
Caused by: java.lang.NullPointerException
We also found another stacktrace from our logs.
error generating report org.eclipse.birt.report.engine.api.EngineException: Exception in reading temporary file for large data set.
Stream closed (Element ID:2634)
at org.eclipse.birt.data.engine.executor.cache.disk.DiskCache.next(DiskCache.java:185)
at org.eclipse.birt.data.engine.executor.cache.disk.DiskCache.fetch(DiskCache.java:206)
at org.eclipse.birt.data.engine.executor.cache.SmartCache.fetch(SmartCache.java:165)
at org.eclipse.birt.data.engine.executor.transform.group.GroupInformationUtil.doGrouping(GroupInformationUtil.java:466)
at org.eclipse.birt.data.engine.executor.transform.pass.PassUtil.pass(PassUtil.java:71)
at org.eclipse.birt.data.engine.executor.transform.pass.ResultSetProcessUtil.prepareAggregations(ResultSetProcessUtil.java:154)
at org.eclipse.birt.data.engine.executor.transform.pass.ResultSetProcessUtil.populateResultSet(ResultSetProcessUtil.java:110)
at org.eclipse.birt.data.engine.executor.transform.pass.ResultSetProcessUtil.doPopulate(ResultSetProcessUtil.java:85)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.prepareQueryResultSet(PassManager.java:108)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.pass(PassManager.java:126)
at org.eclipse.birt.data.engine.executor.transform.pass.PassManager.populateResultSet(PassManager.java:74)
at org.eclipse.birt.data.engine.executor.transform.ResultSetPopulator.populateResultSet
Below is another trace.
ort.engine.api.EngineException: There is an error in saving files of data set cache.
/apps/GTS/tmp/p_wtydm/ccerrep/cache/DataEngine_670338467_23829/DataSetCacheObject_671625063_13907/data.data (Too many open files) (Element ID:2026
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1206)
at org.eclipse.birt.report.engine.executor.ExecutionContext.addException(ExecutionContext.java:1185)
at org.eclipse.birt.report.engine.executor.QueryItemExecutor.executeQuery(QueryItemExecutor.java:96)
at org.eclipse.birt.report.engine.executor.TableItemExecutor.execute(TableItemExecutor.java:62)
at org.eclipse.birt.report.engine.internal.executor.wrap.WrappedReportItemExecutor.execute(WrappedReportItemExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.emitter.ReportItemEmitterExecutor.execute(ReportItemEmitterExecutor.java:46)
at org.eclipse.birt.report.engine.internal.executor.dup.SuppressDuplicateItemExecutor.execute(SuppressDuplicateItemExecutor.java:43)
at org.eclipse.birt.report.engine.internal.executor.l18n.LocalizedReportItemExecutor.execute(LocalizedReportItemExecutor.java:34)
at org.eclipse.birt.report.engine.layout.html.HTMLBlockStackingLM.layoutNodes(HTMLBlockStackingLM.java:65)
at org.eclipse.birt.report.engine.layout.html.HTMLPageLM.layout(HTMLPageLM.java:92)
at org.eclipse.birt.report.engine.layout.html.HTMLReportLayoutEngine.layout(HTMLReportLayoutEngine.java:100)
at org.eclipse.birt.report.engine.presentation.ReportDocumentBuilder.build(ReportDocumentBuilder.java:249)
at org.eclipse.birt.report.engine.api.impl.RunTask.doRun(RunTask.java:260)
We are using eclipse 3.7 and deploying the reports in BEA WL10.0.2 with JDK 1.5. We are creating only one engine and wrapping it in singleton. We are closing Task and Report documents properly. Reports started working fine after bouncing the server. This has become high priority issue in production. Any help on this is highly appreciated.
Pavan.
Re: Reports are failing while closing DataFileReader [message #1009235 is a reply to message #1008904] Thu, 14 February 2013 13:14 Go to previous messageGo to next message
Jason Weathersby is currently offline Jason Weathersby
Pavan
Can you open a bugzilla entry for this? I assume this is on Linux? BTW have you tried something like:
http://www.cyberciti.biz/faq/linux-unix-nginx-too-many-open-files/
Jason
Jason Weathersby
BIRT Exchange
Re: Reports are failing while closing DataFileReader [message #1010856 is a reply to message #1009235] Mon, 18 February 2013 05:51 Go to previous messageGo to next message
Thanks Jason. I will open an entry in bugzilla.
pavan.
Re: Reports are failing while closing DataFileReader [message #1011045 is a reply to message #1010856] Mon, 18 February 2013 13:17 Go to previous messageGo to next message
That would be good. Can you post the bugzilla entry here when you do it?
Jason
Jason Weathersby
BIRT Exchange
Re: Reports are failing while closing DataFileReader [message #1014978 is a reply to message #1011045] Wed, 27 February 2013 00:54 Go to previous messageGo to next message
Hi Jason,
I created a bug in bugzilla. Bug Id is: 401068
Pavan.
Re: Reports are failing while closing DataFileReader [message #1017247 is a reply to message #1011045] Mon, 11 March 2013 05:49 Go to previous messageGo to next message
Hi Jason,
Please let us know if you have any update on this issue.
Pavan.
Re: Reports are failing while closing DataFileReader [message #1017816 is a reply to message #1008904] Tue, 12 March 2013 11:43 Go to previous messageGo to next message
vlad Mising name is currently offline vlad Mising name
No Message Body
[Updated on: Wed, 13 March 2013 06:08]
Report message to a moderator
Re: Reports are failing while closing DataFileReader [message #1017890 is a reply to message #1017247] Tue, 12 March 2013 14:03 Go to previous messageGo to next message
Hi Pavan,
I have investigated the theme and written the result down in the issue:
https://bugs.eclipse.org/bugs/show_bug.cgi?id=401068
Do your reports contain crosstabs?
Vlad
Re: Reports are failing while closing DataFileReader [message #1018556 is a reply to message #1017890] Thu, 14 March 2013 00:05 Go to previous messageGo to next message
Thanks for your reply. None of our reports contans crosstabs.
Pavan.
Re: Reports are failing while closing DataFileReader [message #1031662 is a reply to message #1011045] Mon, 01 April 2013 23:31 Go to previous messageGo to next message
Hi jason,
As per the latest comments from bugzilla for this bug, this issue seems to be resolved in 4.2.2 version. can you please confirm.
Pavan.
Re: Reports are failing while closing DataFileReader [message #1032183 is a reply to message #1031662] Tue, 02 April 2013 13:13 Go to previous message
Michael Williams is currently offline Michael Williams
You might try downloading a copy of 4.2.2 and setting it up to run a quick check on if it works with your actual application. That would definitely be the most absolute way to check that it'll work for you, anyways.
Michael Williams
BIRT Exchange
Michael's BIRT Blog
Previous Topic:by checkbox
Next Topic:The problem about OSGI
Current Time: Sun May 26 03:32:47 EDT 2013
Powered by FUDForum. Page generated in 0.02886 seconds
