Home » Modeling » OCL » [OCLinEcore] Import using metamodel URI(URI vs path)
[OCLinEcore] Import using metamodel URI [message #1008722] Wed, 13 February 2013 13:02 Go to next message
Missing name Mising name is currently offline Missing name Mising name
Hi!
I am currently working with the OCLinEcore-Editor and have a question how to reference other metamodels using the import-Statement.
Currently there are have two plugin-projects "ProjectA" and "ProjectB". Both projects have a metamodel, while ProjectB's metamodel references ProjectA's metamodel.
See the following example for ProjectB's metamodel:
import projecta : '../../ProjectA/model/projectAModel.ecore#/';
--does not work, when the model is not already registered:
--   import projecta : 'http://i.am.projecta/1.0';
import ecore_0 : 'http://www.eclipse.org/emf/2002/Ecore#/';
package  b : b = 'http://i.am.projectb/1.0' {
	class Foo {
		property bar : projecta::Bar;
When working on the two plugins, both of the following scenarios are possible:
1) Both projects are in one workspace. To work on ProjectB's metamodel, I have to reference ProjectA's metamodel by its location/path (as shown in the code snippet above).
2) Plugin ProjectA is already loaded. To work on ProjectB's metamodel I have to change the import to reference the URI of ProjectA's metamodel.
Obviously, changing the imports depending on the workspace configuration is not what I want. I appreciate any kind of help or comments.
Thank you very much!
Kind Regards.
Re: [OCLinEcore] Import using metamodel URI [message #1008746 is a reply to message #1008722] Wed, 13 February 2013 14:06 Go to previous message
You should find that platform:/resource/... paths preferentially use
files in open projects over files in installed plugins.
Ed Willink
On 13/02/2013 18:02, Missing name Mising name wrote:
> Hi!
> import projecta : '../../ProjectA/model/projectAModel.ecore#/'; --does
> class Foo {
> possible:
> comments.
> Kind Regards.
Previous Topic:Property::CompatibleInitialiser' constraint is not satisfied
Next Topic:oclIsTypeOf/oclIsKindOf, OclVoid and OclInvalid
Current Time: Sat May 18 14:09:52 EDT 2013
Powered by FUDForum. Page generated in 0.01853 seconds
