Home » Eclipse Projects » EclipseLink » Simple Auditing Example
Simple Auditing Example [message #1008667] Wed, 13 February 2013 09:18 Go to next message
Marcus Schulz is currently offline Marcus Schulz
I build a webapplication using eclipselink with JPA running in a tomcat.
I build some simple audition that records the creator, change person and some timestamps. All in all my solution uses PersistenceListener and SessionEventListener like shown in this example:
http://wiki.eclipse.org/EclipseLink/Examples/JPA/Auditing#Example_AuditedObject_class
My Problem is, that sometimes the threadLocal.get() for the username is null.
Where is the best place to fill it?
I also tried to set additional properties when creation the entitymanager like this:
 EntityManagerFactory factory = Persistence.createEntityManagerFactory("p1");
        emProperties.put("eclipselink.tenant-id", mandator);
        emProperties.put("username", username);
        emProperties.put("mandator", mandator);
        entityManger =factory.createEntityManager(emProperties);
        ((EntityManagerImpl)entityManger.getDelegate()).getUnitOfWork().setProperty("username", username);
        ((EntityManagerImpl)entityManger.getDelegate()).getUnitOfWork().setProperty("mandator", mandator);
        ((EntityManagerImpl)entityManger.getDelegate()).getSession().setProperty("username", username);
        ((EntityManagerImpl)entityManger.getDelegate()).getSession().setProperty("mandator", mandator);
        ((EntityManagerImpl)entityManger.getDelegate()).getServerSession().setProperty("username", username);
        ((EntityManagerImpl)entityManger.getDelegate()).getServerSession().setProperty("mandator", mandator);
and tried to read them in the EntityListener and SessionListener like this:
public class PersistenceListener implements SessionCustomizer {
	public PersistenceListener() {
	private static InheritableThreadLocal<TransactionInfo> info = new InheritableThreadLocal<TransactionInfo>();
	public static InheritableThreadLocal<TransactionInfo> getInfo() {
		return info;
	public static void setInfo(InheritableThreadLocal<TransactionInfo> info) {
		PersistenceListener.info = info;
	@PreUpdate
	void onPreUpdate(DBObject object) {
		object.setChangeDate(info.get().getTransactionTime());
		object.setChangePerson(info.get().getUsername());
	@PrePersist
	void onPrePersist(DBObject object) {
		object.setCreationDate(info.get().getTransactionTime());
		object.setCreationPerson(info.get().getUsername());
		object.setMandator(info.get().getMandator());
	@PostPersist
	void onPostPersist(DBObject object) {
	@PostLoad
	void onPostLoad(DBObject object) {
	@PostUpdate
	void onPostUpdate(DBObject object) {
	@PreRemove
	void onPreRemove(DBObject object) {
	@PostRemove
	void onPostRemove(DBObject object) {
	private void createTransactionInfo(SessionEvent arg0) {
	public void customize(Session arg0) throws Exception {
		String username = null;
		String mandator = null;
		if (ClientSession.class.isAssignableFrom(arg0.getClass())) {
			username = (String) ((ClientSession) arg0).getProperty("username");
			mandator = (String) ((ClientSession) arg0).getProperty("mandator");
		else if (ServerSession.class.isAssignableFrom(arg0.getClass())) {
			username = (String) ((ServerSession) arg0).getProperty("username");
			mandator = (String) ((ServerSession) arg0).getProperty("mandator");
		if (getInfo().get() == null && (username == null || mandator == null)){
			throw new RuntimeException("Something wicked happened in auditing!");
		getInfo().set(new TransactionInfo(username, Calendar.getInstance(), mandator));
But in the ServerSession the properties are null.
I guess there must be simple solution to pass the user who created the entitymanager instance to the EntityListenr / SessionCustomizer.
In Hibernate I would add an Interceptor to the session created by the SessionFactory holding this data.
I'd be very happy about some hints...no ideas left so far.
Thank you
[Updated on: Wed, 13 February 2013 11:38]
Report message to a moderator
Re: Simple Auditing Example [message #1008711 is a reply to message #1008667] Wed, 13 February 2013 11:39 Go to previous messageGo to next message
Sorry for unformatted code in my post before.
Re: Simple Auditing Example [message #1008996 is a reply to message #1008711] Thu, 14 February 2013 04:15 Go to previous message
Well, I now wrote a wrapper class around the entitymanger with has a persist(DBObject object); Method that writes the auditing information to a threadlocal located in the class DBObject, which is a superclass of all entitites. This seems to work.
Anyway I would be glad if someone did this similar and has good experiences.
Previous Topic:Multitenancy and @EmbeddedId
Next Topic:How to clear cache?
Current Time: Sat May 25 15:22:29 EDT 2013
Powered by FUDForum. Page generated in 0.01522 seconds
