Home » Eclipse Projects » Eclipse 4 » Getting the application Shell at start?
Getting the application Shell at start? [message #1008646] Wed, 13 February 2013 07:09 Go to next message
Alex Kipling is currently offline Alex Kipling
I have the following problem:
when the application Shell is closed by using the close button in the upper right corner - my app data are not fully persisted.
I would like to solve it, by handling the close events of the SWT Shell.
Question:
What would be the right place to hook in for getting the application Shell?
I tried to use Lifecycle - it seems to be too early, since Shell is not available in @PostConstruct.
I registered for IEventManager UIEvents.UILifeCycle.BRINGTOTOP events - it was not triggered.
Re: Getting the application Shell at start? [message #1008647 is a reply to message #1008646] Wed, 13 February 2013 07:13 Go to previous messageGo to next message
Christoph Keimel is currently offline Christoph Keimel
This Thread might include some pointers:
http://www.eclipse.org/forums/index.php/mv/msg/383895/922580/#msg_922580
Re: Getting the application Shell at start? [message #1009025 is a reply to message #1008647] Thu, 14 February 2013 05:01 Go to previous messageGo to next message
Martin Skorsky is currently offline Martin Skorsky
This seems to be related to the lifecycle of the workspace.
If you have your own application, use org.eclipse.ui.application.WorkbenchAdvisor and extend this.
See also http://www.eclipsezone.com/eclipse/forums/t99582.html
Re: Getting the application Shell at start? [message #1009030 is a reply to message #1009025] Thu, 14 February 2013 05:07 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
There's no such class involved in pure e4 apps!
Tom
Am 14.02.13 11:01, schrieb Martin Skorsky:
Re: Getting the application Shell at start? [message #1009097 is a reply to message #1009025] Thu, 14 February 2013 07:31 Go to previous message
Sopot Cela is currently offline Sopot Cela
Martin Skorsky wrote on Thu, 14 February 2013 11:01
This pointer is wrong because the e4 style lifecycles are something completely different from 3.x style LC management and if I got it right the original question is about an e4 app.
I just wanted to enforce this in order to not confuse others who might have the same issue.
Previous Topic:examples of core expression with e4 ?
Next Topic:Window icons in several sizes
Current Time: Fri May 24 22:21:07 EDT 2013
Powered by FUDForum. Page generated in 0.01848 seconds
