Home » Eclipse Projects » Eclipse 4 » IEventBroker inside of the LifeCycle?
IEventBroker inside of the LifeCycle? [message #1008635] Wed, 13 February 2013 06:19 Go to next message
Alex Kipling is currently offline Alex Kipling
Hello!
I tried to use the IEventBroker inside of the LifeCycleManader, to know about
But my trigger is never executed when the application windows is shown.
Why doesn't it work? Any Ideas?
    @PostConstruct
    void postConstruct(final IEclipseContext context) {
        IEventBroker broker = context.get(IEventBroker.class);
        broker.subscribe(UIEvents.UILifeCycle.BRINGTOTOP, new EventHandler() {
            public void handleEvent(Event event) {
                Shell shell = context.get(Shell.class);
                System.out.println("Bringtop");
Re: IEventBroker inside of the LifeCycle? [message #1009248 is a reply to message #1008635] Thu, 14 February 2013 13:52 Go to previous messageGo to next message
Brian de Alwis is currently offline Brian de Alwis
The life cycle manager uses a separate set of annotations. See:
http://wiki.eclipse.org/Eclipse4/RCP/Lifecycle
Brian,
Re: IEventBroker inside of the LifeCycle? [message #1009730 is a reply to message #1009248] Fri, 15 February 2013 10:51 Go to previous messageGo to next message
I am aware of that, but there is no BRINGTOTOP annotation among of them?
Re: IEventBroker inside of the LifeCycle? [message #1009741 is a reply to message #1009730] Fri, 15 February 2013 11:09 Go to previous message
My apologies -- I thought your trigger was referring to your postConstruct() method not being fired.
If you mean BRINGTOTOP being fired, then no, it is only fired by a call to EModelService.bringToTop().
You probably want to listen for UIEvents.ElementContainer.TOPIC_SELECTEDELEMENT.
Brian.
Previous Topic:Window icons in several sizes
Next Topic:Perspective Bar in e4
Current Time: Sun May 26 05:36:43 EDT 2013
Powered by FUDForum. Page generated in 0.01739 seconds
