Home » Modeling » UML2 » UML 2.4 schema
UML 2.4 schema [message #1008038] Fri, 08 February 2013 10:43 Go to next message
Luis Manuel Carril Rodriguez is currently offline Luis Manuel Carril Rodriguez
Hello!
Is it available somewhere a XSD schema to validate the *.uml files?
As the http://www.eclipse.org/uml2/4.0.0/UML link is broken.
Cheers!
Re: UML 2.4 schema [message #1008067 is a reply to message #1008038] Fri, 08 February 2013 11:03 Go to previous messageGo to next message
http://www.eclipse.org/uml2/4.0.0/UML is not a link.
There is no XSD for UML. You could generate one by exporting UML.ecore
but it would omit all the OCL validation constraints.
UML should be validated with a UML tool, such as "Validate" in the UML
Model Editor.
Ed Willink
On 08/02/2013 15:52, Luis Manuel Carril Rodriguez wrote:
> Hello! Is it available somewhere a XSD schema to validate the *.uml
> files?
> Cheers!
Re: UML 2.4 schema [message #1008175 is a reply to message #1008067] Mon, 11 February 2013 04:32 Go to previous messageGo to next message
Thanks Ed,
I simply wanted to check the syntax of external made *.uml (not validate the UML model), without loading it into the Model editor.
Re: UML 2.4 schema [message #1008282 is a reply to message #1008175] Mon, 11 February 2013 04:54 Go to previous messageGo to next message
Well if you only want syntax, any old XMI checker should be equally
superficial. Have you tried XMI.xsd?
Ed
On 11/02/2013 09:32, Luis Manuel Carril Rodriguez wrote:
> Thanks Ed, I simply wanted to check the syntax of external made *.uml
Re: UML 2.4 schema [message #1008589 is a reply to message #1008282] Wed, 13 February 2013 03:44 Go to previous messageGo to next message
Yes I tried the XMI.xsd, but with this I can only check the xmi namespace (nor the uml or the default one); but it´s better than nothing Smile
Luis
Re: UML 2.4 schema [message #1008612 is a reply to message #1008589] Wed, 13 February 2013 04:45 Go to previous message
HI
There are at least 4 OMG UML namespaces and perhaps as many again
MDT/UML2 namespaces. You need to use proper tooling.
Ed Willink
On 13/02/2013 08:44, Luis Manuel Carril Rodriguez wrote:
> nothing :)
> Regards
> Luis
Previous Topic:Stereotype applicable to different elements
Next Topic:CacheAdapter performance issue
Current Time: Tue May 28 17:41:52 EDT 2013
Powered by FUDForum. Page generated in 0.01846 seconds
