Home » Modeling » Epsilon » Palette configuration using Eugenia
Palette configuration using Eugenia [message #1008549] Tue, 12 February 2013 17:43 Go to next message
Hector Florez is currently offline Hector Florez
Dear All
I made my editor using Eugenia, and I need to re-order the elements in the palette by creating new palette groups
Where can I find information or examples??
Hector F
Re: Palette configuration using Eugenia [message #1008639 is a reply to message #1008549] Wed, 13 February 2013 06:42 Go to previous messageGo to next message
Antonio Garcia-Dominguez is currently offline Antonio Garcia-Dominguez
Hi Hector,
We don't have an Eugenia annotation for specifying a different tool group, I'm afraid. We always create two: one for the nodes and another for the links.
You'll need to write a polishing transformation to do that. This tutorial should be useful:
http://eclipse.org/epsilon/doc/articles/eugenia-polishing/
Could you give it a try and tell us if it works for you?
Antonio
Re: Palette configuration using Eugenia [message #1008695 is a reply to message #1008639] Wed, 13 February 2013 10:44 Go to previous messageGo to next message
Hi Antonio
I could modify the palette. However, I also need to remove some elements..
I wrote the next lines, but it doesn't work.
var toolGroupConnections = GmfTool!ToolGroup.all.selectOne(r|r.title = 'Connections');
toolEntry = toolGroupConnections.tools.selectOne(r|r.title = 'ElementToDelete');
toolGroupConnections.entries.remove(toolEntry);
The error log shows the message:
Error
Wed Feb 13 10:39:58 COT 2013
Property 'entries' not found in object org.eclipse.gmf.tooldef.impl.ToolGroupImpl@b077ad
Do you know the solution? or do you know another way to delete the entry?
Thank you so much
Hector F
Re: Palette configuration using Eugenia [message #1008981 is a reply to message #1008695] Thu, 14 February 2013 03:47 Go to previous messageGo to next message
Hi Hector,
According to the EPackage Registry view, GmfTool!ToolGroup doesn't have any feature named "entries". There's one called "tools", though: you might want to use that one.
That view is very handy for writing all this EOL code Smile.
You're welcome,
Antonio
Re: Palette configuration using Eugenia [message #1009267 is a reply to message #1008981] Thu, 14 February 2013 14:48 Go to previous messageGo to next message
Hi Antonio
Thank you so much for your help
I could configure the palette.
Also I made a small example. I hope it can be useful
hflorezf-en.blogspot.com/2013/02/gmf-editor-using-eugenia.html
Hector F
[Updated on: Fri, 15 February 2013 08:26]
Report message to a moderator
Re: Palette configuration using Eugenia [message #1009712 is a reply to message #1009267] Fri, 15 February 2013 10:09 Go to previous message
You're welcome! Thanks for your article as well Smile.
Previous Topic:[EuGENia][EOL]
Next Topic:[EGL] Expected to return a Set, but returned a class
Current Time: Sun May 19 17:05:57 EDT 2013
Powered by FUDForum. Page generated in 0.01837 seconds
