Home » Eclipse Projects » EclipseLink » EclipseLink Download Error(Download User Library for Eclipselink in JPA Facet configuration)
EclipseLink Download Error [message #1006729] Fri, 01 February 2013 11:01 Go to next message
Christopher Straut is currently offline Christopher Straut
I am experiencing a recent problem trying to download Eclipselink in the JPA Facet configuration form in Eclipse. I have selected the EclipseLink 2.4.x and then select the download button. I am then presented a list of the eclipselink download options from 1.1.4 all the way through the current 2.4.1 - Juno release. It then populates the Library Name and Download destination fields. I then select next to accept the terms and conditions and then select the finish button. The download begins and then almost immediately the Transfer Failed dialog appears with the error in opening zip file. This process worked a couple of weeks ago with out any issues. But a couple of days ago I was helping a fellow developer configure their new computer and this is when I noticed the error. I have since tried it on environments that were working (Mac OS X), Windows and Linux to no avail. I also tried even using a 2.3.x version with the same results.
Does anyone know what happened or how to configure the JPA Facet with an externally downloaded Eclipselink install? This worked perfectly a couple of weeks ago with out issue.
Re: EclipseLink Download Error [message #1007214 is a reply to message #1006729] Mon, 04 February 2013 23:29 Go to previous messageGo to next message
Juan Rodriguez is currently offline Juan Rodriguez
Myself and a group of developers working with me in a new project are having the same issue. I have done this many times in the past and never had this happen before. Thanks.
Re: EclipseLink Download Error [message #1007609 is a reply to message #1006729] Wed, 06 February 2013 12:45 Go to previous messageGo to next message
Santiago Hurtado is currently offline Santiago Hurtado
Im having the same issue, any one knows a way around this problem, like download the jar directly?
Re: EclipseLink Download Error [message #1008136 is a reply to message #1007609] Sun, 10 February 2013 14:42 Go to previous messageGo to next message
Joe Perron is currently offline Joe Perron
having same issue.
Re: EclipseLink Download Error [message #1008235 is a reply to message #1006729] Mon, 11 February 2013 11:31 Go to previous messageGo to next message
Jan Schoubo is currently offline Jan Schoubo
Tried this for the first time today, and it failed for me too.
I run Eclipse 4.2 (Juno) on Linux Mint 14.
Any workaround will be much appreciated, as I am writing course material on
Google Cloud SQL.
- Jan
index.php/fa/13371/0/
Jan Schoubo, schoubo reasoning
Re: EclipseLink Download Error [message #1008498 is a reply to message #1006729] Tue, 12 February 2013 13:09 Go to previous messageGo to next message
Neil Hauge is currently offline Neil Hauge
Thanks for notifying us of this issue. I'm currently looking into this with Eclipse.org webmaster.
Neil Hauge
Dali Java Persistence Tools Project
Re: EclipseLink Download Error [message #1008529 is a reply to message #1008498] Tue, 12 February 2013 16:17 Go to previous messageGo to next message
The issue has been identified and we are working on a solution. The issue can be tracked here: https://bugs.eclipse.org/bugs/show_bug.cgi?id=400611.
Neil
Re: EclipseLink Download Error [message #1008562 is a reply to message #1008529] Tue, 12 February 2013 22:22 Go to previous messageGo to next message
This issue should now be resolved.
Neil
Re: EclipseLink Download Error [message #1009017 is a reply to message #1008562] Thu, 14 February 2013 04:57 Go to previous messageGo to next message
Thanks a lot. I can confirm that it works for me now (Juno/Mint 14)
Re: EclipseLink Download Error [message #1011120 is a reply to message #1009017] Mon, 18 February 2013 17:24 Go to previous message
@Niel Hauge, thanks for resolving this issue. I have verified that it works on each of my development environments (OS X, Linux and Windows) with Eclipse Juno.
Previous Topic:Table is referenced twice (due to inheritance?)
Next Topic:No Persistence Services when called from rcp application
Current Time: Wed May 22 18:00:25 EDT 2013
Powered by FUDForum. Page generated in 0.01842 seconds
