Home » Modeling » QVT-OML » Access values between tags via qvto
Access values between tags via qvto [message #1008379] Tue, 12 February 2013 03:54 Go to next message
Andreas Burger is currently offline Andreas Burger
is it possible to access values between tags via qvto?
For example i have something like this in a xml document:
<tag> value </tag>
and the xml is conform to my ecore. In the ecore i marked the element which defines the specific tag as "simple" by the extended metadata.
Nevertheless i can't access the value between the tags.
Does anybody know how i can read out this value using a qvto or an ocl operation?
Andreas
Re: Access values between tags via qvto [message #1008437 is a reply to message #1008379] Tue, 12 February 2013 08:32 Go to previous message
If you used a model as input the tag value should already have been
extracted making access trivial.
OCL (and QVTo) are not primarily designed for text processing, there are
much better languages for that, but if you really must then you need to
look at the functions in the string library. The Juno version added
additional regular expression functions that may help.
Ed Willink
On 12/02/2013 08:54, Andreas Burger wrote:
> Hello,
> <tag> value </tag>
> operation?
> Best regards,
> Andreas
Previous Topic:Specifying concrete output model
Next Topic:Use of Libraries in different Projects
Current Time: Thu May 23 06:53:35 EDT 2013
Powered by FUDForum. Page generated in 0.01630 seconds
