| Tabbed text field using Jface databinding [message #995769] |
Sun, 30 December 2012 23:07  |
Prashant p Messages: 57 Registered: October 2012 |
Member |
I have, for example SSN number (1234-5678). This need to be in two text fields as per attached screenshot. I tried to create, but one only SSN number 1234 gets populated in both text field. What i did is i created POJO which holds SSN value and bind to 2 text field. Instead do i need to create 2 ssn fields in POJO? For example
Initial version
class A{
private string ssn;
Planned change
class A{
private string ssn1
private string ssn2
please help me out
| Re: Tabbed text field using Jface databinding [message #1008409 is a reply to message #995769] |
Tue, 12 February 2013 06:16  |
Nigel Westbury Messages: 7 Registered: July 2009 |
Junior Member |
Hi Prashant,
You can use the DateAndTimeObservableValue class as an example of how to
do this properly. That class splits a single Date timestamp field into
a Date containing the date part only and a Date containing the time part
only, so these can be bound to two controls, one showing the date part
and one the time part.
I know that class is quite big and more complex than perhaps you might
expect. I am hoping this will be addressed in e4 and made simpler.
Nigel Westbury
On 31/12/2012 04:07, Prashant p wrote:
> Initial version
> class A{
> private string ssn;
> Planned change
> class A{
> private string ssn1
> private string ssn2
> please help me out
FUDForum. Page generated in 0.02339 seconds
