Home » Eclipse Projects » Equinox » Question about the OSGI console commands: packages& bundle
Question about the OSGI console commands: packages& bundle [message #1008320] Mon, 11 February 2013 17:19 Go to next message
Aniruddha Shevade is currently offline Aniruddha Shevade
I am trying to see the packages being used by an eclipse plugin, using the eclipse osgi console
The results given by the following 2 commands do not appear consistent
a) When I use the "bundle" command for a plugin , I do not see a particular package listed as imported to eb specific ( javax.xml.bind )
b) When I use the "packages" command it shows that this package is being used by the plugin mentioned above
The given plugin does not directly import the package. So why would it be listed in the packages command?
Which command should I use to find out is a particular package is being used by a plugin?
Any help is appreciated
Ani
Re: Question about the OSGI console commands: packages& bundle [message #1011889 is a reply to message #1008320] Wed, 20 February 2013 07:38 Go to previous message
Libor Jelinek is currently offline Libor Jelinek
Hello Aniruddha!
I'm not responding to your question only want to share my experience
with "packages" command - this command never gave me trustworthy
results. Often it says "No packages export" despite bundle actually
exports a lot of packages.
Maybe it will be worthwhile to file a bug with this inconsistency (in
that case repost bug ID here - I wish to follow up it).
Have a nice day!
Libor Jelinek
http://devblog.virtage.com/libor-jelinek/
> used by a plugin?
> Regards Ani
Previous Topic:Sorting a list of bundles, based on the dependencies between them
Next Topic:Running Equinox application on 64bit Java / Solaris
Current Time: Tue May 21 14:13:20 EDT 2013
Powered by FUDForum. Page generated in 0.01634 seconds
