Home » Eclipse Projects » Eclipse 4 » Command parameters in context menu
Command parameters in context menu [message #1008159] Mon, 11 February 2013 02:35
Jan Kubovy is currently offline Jan Kubovy
I have a tree view and I defined a popup menu for the part the treeview is in. Some of the HandledMenuItems are connected to Commands with parameters. I would like to fill such parameters with a value before the command gets executed depending on the selection of the tree. For example with a resource path stored in the selected item of the tree:
TreeItem selected = tree.getSelection()[0];
IResource resource = (IResource) selected.getData();
String resourcePath = resource.getFullPath().toString();
for (MMenuElement element : contextMenu.getChildren()) {
  if (!(element instanceof MHandledMenuItem))
    continue;
  MHandledMenuItem item = (MHandledMenuItem) element;
  for (MParameter param : item.getParameters()) {
    if (!param.getName().equals("com.example.commandparameter.resource_path"))
      continue;
    param.setValue(resourcePath);
The popup menu is defined under the correct part and is poping up. Just the parameter value is always NULL when it gets executed.
Is there a way how to do that?
I searched but I didn't found how to use parametrized commands with popupmenu.
Thanks for any help!
Jan
Previous Topic:Eclipse 4 menu icon size
Next Topic:How to get view part from Handler
Current Time: Wed May 22 22:46:10 EDT 2013
Powered by FUDForum. Page generated in 0.01494 seconds
