| Re: Xpand integer Global Variable [message #1018183 is a reply to message #1008135] |
Wed, 13 March 2013 06:31  |
Karsten Thoms Messages: 331 Registered: July 2009 Location: Dortmund |
It is not possible to influence the value of an Integer type global var. You could store a datastructure which holds a value of type integer as global var, and then set and get its value.
Or use the counter extensions from org::eclipse::xtend::util::stdlib::counter.
Need professional support for Xtext, Xpand, EMF?
Go to: http://xtext.itemis.com
Twitter : @kthoms
Blog : www.karsten-thoms.de
FUDForum. Page generated in 0.01726 seconds
