Home » Eclipse Projects » EMF-IncQuery » Finding all elements of an association in a subtree(Can you tell me how to do this?)
Finding all elements of an association in a subtree [message #1007892] Thu, 07 February 2013 20:00 Go to next message
Remy Honig is currently offline Remy Honig
I am trying write a query in EMF-IncQuery that returns every note of every category in a subtree of categories. In my Category entity i have a feature named "allNotes" that must return those notes.
So Category2.allNotes should return Note1 and Note2.
And Category2a.allNotes should return Note2.
Category1
\--Category2
     \--Category2a
          \--Note2
     \--Category2b
     \--Note1
\--Category3
This is how my model look like:
class Notebook
	contains Note[] notes opposite notebook
	contains Category[] categories opposite notebook
class Note
	String text
	container Notebook notebook opposite notes
        refers Category[] categories opposite notes
class Category
	refers Note[] notes opposite categories
	refers Note[] allNotes
	contains Category[] children opposite parent
	container Notebook notebook opposite categories
	container Category parent opposite children
The query below only return the Notes inside one Category.
@DerivedFeature
pattern allNotes(C: Category, N: Note) {
	Category.notes(C, N);
What should my query look like to do what I want?
Re: Finding all elements of an association in a subtree [message #1007993 is a reply to message #1007892] Fri, 08 February 2013 09:52 Go to previous messageGo to next message
Zoltan Ujhelyi is currently offline Zoltan Ujhelyi
Member
currently there is no operator for traversing the containment hierarchy generically, however, you could use some helper patterns to get what you want. I suggest something as follows:
 * Subcategory relation
pattern subCategory(c : Category, s : Category) {
  Category.children(c, s);
 * List of all categories contained in the selected Category 'c'. The result also includes 'c'.
pattern allSubCategories(c : Category, s : Category) {
  c == s;
} or {
  //This is required as find subCategory+ does no return direct relations; and there is no find subCategory* support in the language
  find subCategory(c, s);
} or {
  find subCategory+(c, s);
@DerivedFeature
pattern allNotes(c: Category, n: Note) {
  find allSubCategories(c, s);
  Category.notes(s, n);
If you would have multiple paths to check in the containment hierarchy, your helper patterns should look for those cases as well.
I hope, this is helps.
Zoltán
Re: Finding all elements of an association in a subtree [message #1008042 is a reply to message #1007993] Fri, 08 February 2013 10:53 Go to previous messageGo to next message
Hi Zoltán,
I also found an old github ticket (github.com/ujhelyiz/EMF-IncQuery/issues/350) of your project which I found helpful as well.
My patterns now look like this as you suggested, but I did not add
...or {find subCategories(This, Child);}...
and still I get the result I was expecting. Not sure why that is.
private pattern subCategories(This: Category, Child: Category) {
	Category.children(This, Child);
private pattern thisAndSubCategories(This: Category, Child: Category) {
	find subCategories+(This, Child);
} or {
	This == Child;
@DerivedFeature
pattern allNotes(This: Category, Notes: Note) {
	find thisAndSubCategories(This, Child);
	Category.notes(Child, Notes);
Thank your for your help, I greatly appreciate it.
Re: Finding all elements of an association in a subtree [message #1008160 is a reply to message #1008042] Mon, 11 February 2013 02:43 Go to previous message
Abel Hegedus is currently offline Abel Hegedus
Just a quick clarification:
The pattern you wrote is correct and it gives the expected results as required.
Contrary to what Zoltán said, the + operator does include direct references, what it does not include is the "source" element, which is why the "{c == s}" pattern body is required.
Previous Topic:Unable to install EMF IncQuery
Next Topic:Warning about cartesian product seems unnecessary in some cases
Current Time: Sat May 25 07:07:49 EDT 2013
Powered by FUDForum. Page generated in 0.03375 seconds
