Home » Modeling » EMF » Exception thrown with EMF 2.9 and RAP 2.0(ExtendedImageRegistry seems broken)
Exception thrown with EMF 2.9 and RAP 2.0 [message #1007818] Thu, 07 February 2013 10:22 Go to next message
Tiago Simoes is currently offline Tiago Simoes
Hi all,
I was evaluating the migration of an RAP 1.5 and EMF 2.8 application to the latest RAP 2.0 and EMF 2.9 builds (preparing for the future ahead).
Everything seems to work great out of the box except for the following problem, when I try to open an generated editor I get a ClassNotFoundException for the class SessionSingletonBase (which was replaced by SingletonUtil in RAP 2.0).
After analyzing the exception trace it seems the culprit is the ExtendedImageRegistry class, in particular the following code:
try
      Class<?> singletonUtilityClass = CommonPlugin.loadClass("org.eclipse.rap.rwt", "SingletonUtil");
      instanceMethod = singletonUtilityClass.getMethod("getSessionInstance", Class.class);
    catch (Exception exception)
      try
        Class<?> singletonUtilityClass = CommonPlugin.loadClass("org.eclipse.rap.rwt", "SessionSingletonBase");
        instanceMethod = singletonUtilityClass.getMethod("getInstance", Class.class);
      catch (Exception exception2)
        EMFEditUIPlugin.INSTANCE.log(exception2);
So it seems the class is already prepared for RAP 2.0 since it tries to load the SingletonUtil class, however due to some strange reason the class is not found.
Note that everything else works fine in the application which means that the SingletonUtil class is used in other non EMF places correctly.
Is it a bug or something I overlooked?
Thanks!
Re: Exception thrown with EMF 2.9 and RAP 2.0 [message #1007990 is a reply to message #1007818] Fri, 08 February 2013 01:24 Go to previous messageGo to next message
Ed Merks is currently offline Ed Merks
Sorry, yes was reported as
https://bugs.eclipse.org/bugs/show_bug.cgi?id=399246. I'll commit the
fix today.
On 07/02/2013 7:18 PM, TSimoes Mising name wrote:
> Hi all,
> ahead).
> try
> instanceMethod =
> try
> Class.class);
> Thanks!
Re: Exception thrown with EMF 2.9 and RAP 2.0 [message #1014750 is a reply to message #1007990] Tue, 26 February 2013 06:47 Go to previous message
Konstantinos Apostolou is currently offline Konstantinos Apostolou
I have the same problem!
allow me to correct the link https://bugs.eclipse.org/bugs/show_bug.cgi?id=399246
the dot in the end Smile
Previous Topic:[CDO] 4.2 and CDOElementProxy
Next Topic:[CDO]Net4J Oracle Adaptor - schema generation exception
Current Time: Sun May 19 09:28:39 EDT 2013
Powered by FUDForum. Page generated in 0.01487 seconds
