Home » Eclipse Projects » Eclipse 4 » creating input part via part descriptor
creating input part via part descriptor [message #1007776] Thu, 07 February 2013 08:32 Go to next message
Jan Weidauer is currently offline Jan Weidauer
Member
Hi there!
In my RCP-Application I have defined a PartDescriptor within a
Perspective and want to place an InputPart there.
Because in PartService there is no method createInputPart(String
descriptorID) I created a utility method using the code from
PartService.createPart(MPartDescriptor descriptor).
public static MInputPart createInputPart(String id, String inputURI,
EPartService partService) {
MPart part = partService.createPart(id);
MInputPart inputPart = MBasicFactory.INSTANCE.createInputPart();
inputPart.setInputURI(inputURI);
inputPart.setElementId(part.getElementId());
inputPart.getMenus().addAll(EcoreUtil.copyAll(part.getMenus()));
if (part.getToolbar() != null) {
inputPart.setToolbar((MToolBar)EcoreUtil.copy((EObject)part.getToolbar()));
inputPart.setContributorURI(part.getContributorURI());
inputPart.setCloseable(part.isCloseable());
inputPart.setContributionURI(part.getContributionURI());
inputPart.setLabel(part.getLabel());
inputPart.setIconURI(part.getIconURI());
inputPart.setTooltip(part.getTooltip());
inputPart.getHandlers().addAll(EcoreUtil.copyAll(part.getHandlers()));
inputPart.getTags().addAll(part.getTags());
inputPart.getBindingContexts().addAll(part.getBindingContexts());
return inputPart;
Using the returned InputPart I get an InjectionException because there
is no MDirtyable found to inject into my PartContribution class.
Using the part via partService.createPart(id) all works well.
partService.showPart(inputPart, PartState.ACTIVATE); -> Exception
partService.showPart(part, PartState.ACTIVATE); -> everything is fine
I debugged the code and can't find a difference. What am I doing wrong?
Jan
Re: creating input part via part descriptor [message #1007787 is a reply to message #1007776] Thu, 07 February 2013 08:52 Go to previous messageGo to next message
Thomas Schindl is currently offline Thomas Schindl
MInputPart extends MPart so the MDirtyable sounds strange. It might help
us if you are showing the Exception Stacktrace.
Tom
Am 07.02.13 14:32, schrieb Jan Weidauer:
> Hi there!
> return inputPart;
> Jan
Re: creating input part via part descriptor [message #1007797 is a reply to message #1007787] Thu, 07 February 2013 09:07 Go to previous messageGo to next message
Member
!ENTRY org.eclipse.e4.ui.workbench 4 0 2013-02-07 15:02:22.056
!MESSAGE Unable to create class
'de.servalse.ebas.rcp.lvr.demo.ui.parts.FachfunktionEditor' from bundle
'459'
!STACK 0
org.eclipse.e4.core.di.InjectionException: Unable to process
"FachfunktionEditor.dirty": no actual value was found for the argument
"MDirtyable".
org.eclipse.e4.core.internal.di.InjectorImpl.reportUnresolvedArgument(InjectorImpl.java:394)
org.eclipse.e4.core.internal.di.InjectorImpl.resolveRequestorArgs(InjectorImpl.java:385)
org.eclipse.e4.core.internal.di.InjectorImpl.inject(InjectorImpl.java:100)
org.eclipse.e4.core.internal.di.InjectorImpl.internalMake(InjectorImpl.java:319)
at org.eclipse.e4.core.internal.di.InjectorImpl.make(InjectorImpl.java:240)
org.eclipse.e4.core.contexts.ContextInjectionFactory.make(ContextInjectionFactory.java:161)
org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.createFromBundle(ReflectionContributionFactory.java:102)
org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.doCreate(ReflectionContributionFactory.java:71)
org.eclipse.e4.ui.internal.workbench.ReflectionContributionFactory.create(ReflectionContributionFactory.java:53)
org.eclipse.e4.ui.workbench.renderers.swt.ContributedPartRenderer.createWidget(ContributedPartRenderer.java:141)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createWidget(PartRenderingEngine.java:896)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:630)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.safeCreateGui(PartRenderingEngine.java:732)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.access$2(PartRenderingEngine.java:703)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$7.run(PartRenderingEngine.java:697)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.createGui(PartRenderingEngine.java:682)
org.eclipse.e4.ui.workbench.renderers.swt.StackRenderer.showTab(StackRenderer.java:1114)
org.eclipse.e4.ui.workbench.renderers.swt.LazyStackRenderer$1.handleEvent(LazyStackRenderer.java:67)
org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4687)
org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
org.eclipse.e4.ui.model.application.ui.impl.ElementContainerImpl.setSelectedElement(ElementContainerImpl.java:171)
org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.showElementInWindow(ModelServiceImpl.java:418)
org.eclipse.e4.ui.internal.workbench.ModelServiceImpl.bringToTop(ModelServiceImpl.java:385)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.delegateBringToTop(PartServiceImpl.java:579)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:558)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:532)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.activate(PartServiceImpl.java:521)
org.eclipse.e4.ui.internal.workbench.PartServiceImpl.showPart(PartServiceImpl.java:978)
de.servalse.ebas.rcp.lvr.demo.handlers.OpenEditorHandler.execute(OpenEditorHandler.java:55)
org.eclipse.e4.core.internal.di.MethodRequestor.execute(MethodRequestor.java:56)
org.eclipse.e4.core.internal.di.InjectorImpl.invokeUsingClass(InjectorImpl.java:229)
org.eclipse.e4.core.internal.di.InjectorImpl.invoke(InjectorImpl.java:210)
org.eclipse.e4.core.contexts.ContextInjectionFactory.invoke(ContextInjectionFactory.java:131)
org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:171)
org.eclipse.e4.core.commands.internal.HandlerServiceImpl.executeHandler(HandlerServiceImpl.java:145)
de.servalse.ebas.rcp.lvr.demo.ui.parts.MainPart.openEditor(MainPart.java:198)
de.servalse.ebas.rcp.lvr.demo.ui.parts.MainPart.access$0(MainPart.java:180)
de.servalse.ebas.rcp.lvr.demo.ui.parts.MainPart$2.doubleClick(MainPart.java:142)
org.eclipse.jface.viewers.StructuredViewer$1.run(StructuredViewer.java:845)
at org.eclipse.jface.util.SafeRunnable$1.run(SafeRunnable.java:128)
at org.eclipse.jface.util.SafeRunnable.run(SafeRunnable.java:175)
org.eclipse.jface.viewers.StructuredViewer.fireDoubleClick(StructuredViewer.java:843)
org.eclipse.jface.viewers.StructuredViewer.handleDoubleSelect(StructuredViewer.java:1134)
org.eclipse.jface.viewers.StructuredViewer$4.widgetDefaultSelected(StructuredViewer.java:1246)
org.eclipse.jface.util.OpenStrategy.fireDefaultSelectionEvent(OpenStrategy.java:249)
at org.eclipse.jface.util.OpenStrategy.access$0(OpenStrategy.java:246)
at org.eclipse.jface.util.OpenStrategy$1.handleEvent(OpenStrategy.java:307)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1053)
at org.eclipse.swt.widgets.Display.runDeferredEvents(Display.java:4169)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3758)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
org.eclipse.core.databinding.observable.Realm.runWithDefault(Realm.java:332)
org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
org.eclipse.e4.ui.internal.workbench.swt.E4Application.start(E4Application.java:150)
de.servalse.ebas.rcp.application.RestartableApplication.start(RestartableApplication.java:16)
org.eclipse.equinox.internal.app.EclipseAppHandle.run(EclipseAppHandle.java:196)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.runApplication(EclipseAppLauncher.java:110)
org.eclipse.core.runtime.internal.adaptor.EclipseAppLauncher.start(EclipseAppLauncher.java:79)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
at org.eclipse.equinox.launcher.Main.run(Main.java:1438)
at org.eclipse.equinox.launcher.Main.main(Main.java:1414)
The contribution class:
public class FachfunktionEditor {
@Inject private MDirtyable dirty;
@Inject private Logger log;
private Label label;
@PostConstruct
public void postConstruct(Composite parent) {
label = new Label(parent, SWT.NONE);
label.setText("testing dirty");
this.dirty.setDirty(true);
@Focus
public void setFocus() {
this.label.setFocus();
Re: creating input part via part descriptor [message #1007965 is a reply to message #1007797] Thu, 07 February 2013 10:20 Go to previous messageGo to next message
Ok - that looks very strange. Can you please set a breakpoint in
PartRenderingEngine.populateModelInterfaces() and see which context-keys
are pushed there please.
It would be good to have a small standalone sample to debug the problem
and a bugzilla because this looks like a bug to me.
What if you use "@Inject MInputPart dirty" instead of MDirtyable?
Tom
Am 07.02.13 15:07, schrieb Jan Weidauer:
> '459'
> !STACK 0
> "MDirtyable".
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.core.runtime.SafeRunner.run(SafeRunner.java:42)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at org.eclipse.swt.widgets.EventTable.sendEvent(EventTable.java:84)
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> at
> @PostConstruct
> @Focus
Re: creating input part via part descriptor [message #1007966 is a reply to message #1007965] Thu, 07 February 2013 11:18 Go to previous messageGo to next message
Member
Ok, while reimplementing the stuff for a small example I found the
failure: I messed up with the context, overwriting the part context with
a newly created.
Anyway, thanks for help Tom!
Greetings,
Jan
Re: creating input part via part descriptor [message #1007967 is a reply to message #1007966] Thu, 07 February 2013 13:19 Go to previous messageGo to next message
Now you know why we always force you to strap down your problem, at
least 50% of the time people find the problem in their code ;-) Good
news for us we don't have a major bug in our system.
Tom
Am 07.02.13 17:18, schrieb Jan Weidauer:
> a newly created.
> Greetings,
> Jan
Re: creating input part via part descriptor [message #1008259 is a reply to message #1007967] Mon, 11 February 2013 09:57 Go to previous messageGo to next message
Member
I noticed that I was partly wrong. I did not overwrite an existing
context because the part I created has no context.
I investigated this a little further and found that a part gets his own
context when rendered. There is a comment in the PartRenderingEngine
source code that the context should be null before rendering. So when I
create a context to put own information in it, the partrenderer fails to
create the proper context.
This means I can't use the context to deliver information to my part. Or
do I miss something?
Jan
Re: creating input part via part descriptor [message #1008260 is a reply to message #1008259] Mon, 11 February 2013 10:10 Go to previous messageGo to next message
Well you can pass on informations through the MPart#properties but those
are only String values. What values do you want to pass?
Tom
Am 11.02.13 15:57, schrieb Jan Weidauer:
> Jan
Re: creating input part via part descriptor [message #1008261 is a reply to message #1008260] Mon, 11 February 2013 10:22 Go to previous messageGo to next message
Member
I want to pass a data object as input for an editor.
Jan
Re: creating input part via part descriptor [message #1008262 is a reply to message #1008261] Mon, 11 February 2013 10:54 Go to previous messageGo to next message
Well the original idea with InputPart was to one would use something
like an URI and then pass on this URI to a factory get the real input
object - similar to IEditorInput in 3.x.
What are you using the URI for.
If I would have the time to implement it. I'd envision it working
something like this:
MInpuPart p = ....
p.setInputURI("my-protocol://MyObject@[id=1]");
Then would provide a ResourceFactoryService which looks something like this:
interface ResourceFactory {
public <O> O loadResource(String resourceURI) {
which can be registered for a protocol e.g. "my-protocol" and finally an
annotation like e.g. @InputResource.
class MyInputView {
@PostConstruct
void init(@InputResource MyObject myObject) {
Tom
Am 11.02.13 16:22, schrieb Jan Weidauer:
> Jan
Re: creating input part via part descriptor [message #1008301 is a reply to message #1008262] Mon, 11 February 2013 14:55 Go to previous messageGo to next message
Member
the data is loaded from a database and then presented for selection for
further work. This selection can be done in an overview or in a dialog
or something like this. That means the data object exists already at the
time of selection. In 3.x I created my own EditorInput as container for
the data object and passed it to the editor.
In e4 I wanted to avoid implementing the mechanism you described using
the InputURI, because following this way I have to create, pass and
parse an URI to an resource I already have in my hands. That is a little
too much in my thoughts. But in the end it seems the only correct way...
Thanks for help again :)
Jan
Re: creating input part via part descriptor [message #1008318 is a reply to message #1008301] Mon, 11 February 2013 16:42 Go to previous messageGo to next message
Well you can naturally push stuff in an upper context e.g. the one of
the perspective or window. The context created is a child of this context.
Tom
Am 11.02.13 20:55, schrieb Jan Weidauer:
> Jan
Re: creating input part via part descriptor [message #1008431 is a reply to message #1008318] Tue, 12 February 2013 07:53 Go to previous message
Member
Am 11.02.2013 16:54, schrieb Tom Schindl:> Hi,
this:
Would you mind giving me a hint how to register a service for a
protocol, please?
Jan
Previous Topic:How to get view part from Handler
Next Topic:Clearing model data without clearing preferences
Current Time: Sat May 25 09:51:34 EDT 2013
Powered by FUDForum. Page generated in 0.02145 seconds
