Home » Eclipse Projects » BPMN 2.0 Modeler » Stacktrace on right click.
Stacktrace on right click. [message #1006751] Fri, 01 February 2013 11:44 Go to next message
Rui Domingues is currently offline Rui Domingues
I checked out BPMN2 Modeler, and it works well, but when for instance I right click in diagram, the stack bellow is shown. Which dependency am I missing, or better, how can I solve this.
thanks
!STACK 0
java.io.FileNotFoundException: /IMG_TOOL_COPY
at org.eclipse.osgi.framework.internal.protocol.bundleentry.Handler.findBundleEntry(Handler.java:44)
at org.eclipse.osgi.framework.internal.core.BundleResourceHandler.openConnection(BundleResourceHandler.java:175)
at java.net.URL.openConnection(URL.java:971)
at org.eclipse.core.internal.boot.PlatformURLConnection.connect(PlatformURLConnection.java:110)
at org.eclipse.core.internal.boot.PlatformURLConnection.getURLAsLocal(PlatformURLConnection.java:238)
at org.eclipse.core.internal.runtime.PlatformURLConverter.toFileURL(PlatformURLConverter.java:36)
at org.eclipse.core.runtime.FileLocator.toFileURL(FileLocator.java:206)
at org.eclipse.jface.resource.URLImageDescriptor.getFilePath(URLImageDescriptor.java:137)
at org.eclipse.jface.resource.URLImageDescriptor.createImage(URLImageDescriptor.java:157)
at org.eclipse.jface.resource.ImageDescriptor.createResource(ImageDescriptor.java:165)
at org.eclipse.jface.resource.DeviceResourceManager.allocate(DeviceResourceManager.java:56)
at org.eclipse.jface.resource.AbstractResourceManager.create(AbstractResourceManager.java:88)
at org.eclipse.jface.resource.LocalResourceManager.allocate(LocalResourceManager.java:82)
at org.eclipse.jface.resource.ResourceManager.createImage(ResourceManager.java:172)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.getImage(HandledContributionItem.java:598)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.updateIcons(HandledContributionItem.java:571)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.update(HandledContributionItem.java:471)
at org.eclipse.e4.ui.workbench.renderers.swt.HandledContributionItem.update(HandledContributionItem.java:461)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRenderer$4.handleEvent(MenuManagerRenderer.java:202)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler$1.run(UIEventHandler.java:41)
at org.eclipse.swt.widgets.Synchronizer.syncExec(Synchronizer.java:180)
at org.eclipse.ui.internal.UISynchronizer.syncExec(UISynchronizer.java:150)
at org.eclipse.swt.widgets.Display.syncExec(Display.java:4291)
at org.eclipse.e4.ui.internal.workbench.swt.E4Application$1.syncExec(E4Application.java:187)
at org.eclipse.e4.ui.services.internal.events.UIEventHandler.handleEvent(UIEventHandler.java:38)
at org.eclipse.equinox.internal.event.EventHandlerWrapper.handleEvent(EventHandlerWrapper.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:197)
at org.eclipse.equinox.internal.event.EventHandlerTracker.dispatchEvent(EventHandlerTracker.java:1)
at org.eclipse.osgi.framework.eventmgr.EventManager.dispatchEvent(EventManager.java:230)
at org.eclipse.osgi.framework.eventmgr.ListenerQueue.dispatchEventSynchronous(ListenerQueue.java:148)
at org.eclipse.equinox.internal.event.EventAdminImpl.dispatchEvent(EventAdminImpl.java:135)
at org.eclipse.equinox.internal.event.EventAdminImpl.sendEvent(EventAdminImpl.java:78)
at org.eclipse.equinox.internal.event.EventComponent.sendEvent(EventComponent.java:39)
at org.eclipse.e4.ui.services.internal.events.EventBroker.send(EventBroker.java:81)
at org.eclipse.e4.ui.internal.workbench.UIEventPublisher.notifyChanged(UIEventPublisher.java:58)
at org.eclipse.emf.common.notify.impl.BasicNotifierImpl.eNotify(BasicNotifierImpl.java:374)
at org.eclipse.e4.ui.model.application.ui.menu.impl.ItemImpl.setEnabled(ItemImpl.java:264)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerRendererFilter.updateElementVisibility(MenuManagerRendererFilter.java:215)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.showMenu(MenuManagerShowProcessor.java:139)
at org.eclipse.e4.ui.workbench.renderers.swt.MenuManagerShowProcessor.menuAboutToHide(MenuManagerShowProcessor.java:101)
at org.eclipse.jface.internal.MenuManagerEventHelper.showEventPostHelper(MenuManagerEventHelper.java:55)
at org.eclipse.jface.action.MenuManager.handleAboutToShow(MenuManager.java:476)
at org.eclipse.jface.action.MenuManager.access$1(MenuManager.java:470)
at org.eclipse.jface.action.MenuManager$2.menuShown(MenuManager.java:500)
at org.eclipse.swt.widgets.TypedListener.handleEvent(TypedListener.java:255)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1276)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1300)
at org.eclipse.swt.widgets.Widget.sendEvent(Widget.java:1281)
at org.eclipse.swt.widgets.Menu._setVisible(Menu.java:198)
at org.eclipse.swt.widgets.Display.runPopups(Display.java:3596)
at org.eclipse.swt.widgets.Display.readAndDispatch(Display.java:3169)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine$9.run(PartRenderingEngine.java:1029)
at org.eclipse.e4.ui.internal.workbench.swt.PartRenderingEngine.run(PartRenderingEngine.java:923)
at org.eclipse.e4.ui.internal.workbench.E4Workbench.createAndRunUI(E4Workbench.java:86)
at org.eclipse.ui.internal.Workbench$5.run(Workbench.java:588)
at org.eclipse.ui.internal.Workbench.createAndRunWorkbench(Workbench.java:543)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:353)
at org.eclipse.core.runtime.adaptor.EclipseStarter.run(EclipseStarter.java:180)
at sun.reflect.NativeMethodAccessorImpl.invoke(NativeMethodAccessorImpl.java:57)
at java.lang.reflect.Method.invoke(Method.java:601)
at org.eclipse.equinox.launcher.Main.invokeFramework(Main.java:629)
at org.eclipse.equinox.launcher.Main.basicRun(Main.java:584)
Re: Stacktrace on right click. [message #1006761 is a reply to message #1006751] Fri, 01 February 2013 12:18 Go to previous messageGo to next message
Robert Brodt is currently offline Robert Brodt
Yikes! It's hard to tell just from a stacktrace exactly what's missing/broken. Which version of eclipse are you using, and what is the build ID of the BPMN2 editor?
I would recommend installing a clean copy of eclipse, installing the latest version of BPMN2 editor (hopefully it should work!) and compare the new environment against this "broken" one (Help->About->Installation Details->Plug-ins).
Please let me know if you are able to resolve this problem.
Bob
Re: Stacktrace on right click. [message #1007610 is a reply to message #1006761] Wed, 06 February 2013 12:47 Go to previous messageGo to next message
I'm using JUNO 4.2.1
I'm using nightly builds. I have all projects instantiated in my workspace.
Maybe this is the same issue that happens with e4 RCP, which dont find certain images for some 3.x views. Should I run this in Indigo? (I think I've read some broadcasted e-mail about JUNO support). I also have graphiti 0.9.1.
I'll check it out (about images).
Best Greets
Re: Stacktrace on right click. [message #1007774 is a reply to message #1007610] Thu, 07 February 2013 08:26 Go to previous message
Actually we are developing on Juno with graphiti 0.9.1 as well as trying to keep backwardly compatible with Indigo and Helios (which uses graphiti 0.8.2) I haven't tested with e4 RCP yet. The FileNotFoundException referencing IMG_TOOL_COPY appears to point to a GEF menu action. Please let me know if you figure this one out.
Previous Topic:Remove shelf from pallette
Next Topic:Release 0.2.2 now available
Current Time: Thu May 23 07:14:37 EDT 2013
Powered by FUDForum. Page generated in 0.01961 seconds
